Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
AllanV
Quote from: color on August 27, 2020, 09:48:43 PM
https://www.youtube.com/watch?v=srI7STFU5Mk&t=205s
https://www.youtube.com/watch?v=lcKsIpdsWUA
If you sell a Bedini generator for more than $10,000, which can be made for just $500, it is natural for investors to get angry later when they learn the facts.
There seems to be someone at this cafe who knows who the last unsuspecting investor is.
This is the case when you started knowing that it was impossible to recover your investment from the beginning.
Bedini generators are well known around the world.
Andrei must have known this cafe well.
The rumors are fast.
Does this look like Wesley?
I am a person who desperately wants members to experiment freely and sell generators.
Honesty is greater than commercial morality.
Hi color,
I have read some of your comments.
I am new at posting and may have something to add so I will not hold back.
Selling generators would prove difficult. Think it through, making something and keeping it quiet sounds better.
There are stories of the ridiculing and disbelief even when the people are standing right there. Inventors of such devices pack up their equipment and go home. If they live.
The magnetic field in a 50hz, 80watt 240volt transformer is 0.032 watts equivalent this means it is 1/2500th and 47AT. (1350t)
It operates barely above residual magnetism with no current at all. There is a sticking point that needs to be understood.
What happens in a transformer?
It seems the input and output take turns at passing the larger current in each half wave. Every quarter cycle the conditions change. Two windings interact together with a little tension when currents are going in opposite directions and have slightly more current than the other alternately. This changes the magnetic polarity in a half wave. Maximum current occurs with no magnetism. The flux builds as the currents are slowed down to a stop with more in one than the other at a point in time. Maximum voltage occurs with the flux as well.
A low voltage circuit can be used to pass a current in a circle through unequal turns in a 1/4 cycle to produce flux and then the currents change direction with a change in the number of turns to produce enough electric force to drive down the magnetism into the opposite polarity.
If these currents are set by an inductor in separate circuits, a maximum of 10-15% more current can be passed through one winding than the other using a high voltage. This small current 0.2A high voltage 50-70V charges a capacitor and through 300t can produce 60AT which adds to the low voltage circuit up to 60AT = 120AT. This much flux will drive current and voltage swings in a core of large cross section.
The input and output are left to float, one with a capacitor and the other a load. A small inductor with two windings is used to block the wrong current direction in each circuit because the currents must flow in opposite directions through the transformer.
The input into the transformer is by controlling the the amount of difference in current flow in each winding every 1/4 cycle. It is done to build the flux.
My background is engineering and it is sometimes essential to go back to basics.
I do not understand exactly what you are doing but will keep looking. What I am doing may have some relevance or not.
color
AllanV:
I trust the words of anyone who reveals the generator they make.
We can respond to you by revealing your generator.
Please ask for photos and videos.
It's a good idea to watch out for Wesley's various names at the cafe. 8) ::)
color
Everything appears as 500W X 4 standard lights.
The oscilloscope may malfunction while the generator is running.
A acquaintance of mine said.
I don't know why.
So I choose and trust the words of the person who makes the Ruslan generator.
The E-type transformer uses a newly wound transformer on a new bobbing.
All I can say is this.
https://www.youtube.com/watch?v=zgEecYI5ZQU
color
I am talking on the premise that the three-phase transformer below is resonant, and I have never seen such a transformer in real life.
No one understands Kapanadze, or Kapanadze's cousin's aquarium generator transformer, and experiment with the real thing.
So all we can do is predict.
The prediction is not a test of Kapanadze or cousin of Kapanadze, but only our imagination.
It is recommended to experiment with a TV Yoke-transformer.
Primary coil is 6 x 6 windings (PSU 12V)
Primary coil is 12 X 12 windings (PSU 24V)
color
Even a very simple experiment is replaced by a question, and without an oscilloscope I cannot answer.
It would be faster than my answer to show you what you are experimenting with.
