Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
0 Members and 49 Guests are viewing this topic.
color
황도이장
https://www.youtube.com/watch?v=_2-_cv1X6fI&t=22s
https://www.youtube.com/watch?v=u3GFt7Ywky0
https://www.youtube.com/watch?v=VEq0GxNUKdw&t=95s
There are thousands of islands like this in my country.
And there are many people living on the island from generation to generation.
Of course, the electricity facility is all solar charging batteries. ;D ::)
AllanV
Quote from: color on August 28, 2020, 08:23:54 PM
AllanV:
Requests the disclosure of the device you have created.
Then my expert group can verify your device.
Hi color,
I have made my mind up to do it. But not just for your group. It will crash the world economy by trillions of dollars and make many unhappy faces with murderous intentions.
It seems it was all known in 1903. I have received some advice that what I describe is how Figuera explains his device.
Some of his writing has now been read and I agree. His generator looks similar to a wave winding with a commutator for switching. And the tapping on the coils look interesting as well.
When the two currents flow in opposite directs in the two equal number of turns of the windings in a transformer no flux is present because the magnetic fields cancel out. If one current increases slightly greater than the other there is immediate flux created. If then this current decreases as the other increases the flux immediately changes polarity. No real energy is required to do this change but it builds the flux to some strength at the same time as voltage is maximized for the next half cycle.
You could do this now with resistors and a couple of variable ones as well. Most transformers have two equal output windings.
Connect a volt meter to the i/p winding and as the variable resistors are quickly changed in turn it should show some output.
Power is not usually taken from the input winding because it is the transformer action in two windings that builds the voltage in both of them.
In an 80 watt transformer 50Hz 240 volt 0.333A load current only 0.9volt 0.031A DC will produce the flux. It is 1/2500 of the load power.
Virtually nothing, if it is modulated in a device with two windings that are set up correctly as a driver driven situation 80 watts can be produced from 0.035Watt. In reality it needs a little more but the tendency is to over do the situation.
When AC is applied certain conditions are set up that inhibit but with some thought these problems are resolved.
All the best,
Allan
color
AllanV :
Generators and schematics you create will be validated by my expert group as soon as they are published.
And your hobbies and the world have nothing to do with it.
And do you need someone's permission to make a generator?
It's hard for me to understand the strange way of thinking of Westerners.
Is it just you?
AllanV
Quote from: color on August 29, 2020, 01:05:54 AM
AllanV :
Is it just you?
Hi Color,
Your experts don't look very expert.
x the unknown quantity and spert the drip under pressure. I don't like the word so use it often.
I live in a quiet peaceful place and do not like to be lumped in with millions of others in a general statement.
I am losing respect for you and maybe you have issues and are the problem.
Allan
color
AllanV :
Is it difficult to disclose your generator and circuit diagram?
Don't come here to excuse.
And in the Korean electric cafe community where I belong, verification is a major event.
Your article is being posted in the Korean Electric Cafe.
All you have to do is disclose the generator and schematic you have created.
