Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
joaouchoa and 199 Guests are viewing this topic.
justawatt
Quote from: AlienGrey on December 16, 2020, 08:19:37 PM
So is your equivalent yoke or torrid core got 8 +8 turns on the primary and 20 to 25 turns on the secondary nothing else ?
Mine device uses 20 + 20 primary , resonance 5 turns
Supply voltage 12 volt.
If you are going for 8 +8 turns use 24 volt
And I have put small paper on one side of yoke before joining. The device when started first I don't get the wave.
I have to wait for some time  ,on and off to get this waveform .
Ones I get the waveform no need for this process.
You can on and off the device it works.
So one thing I notice after some time the yoke is farm to touch. Don't know if it plays role.
And the way granade is wound 38 m and resonance 19 m.
Jeg
Quote from: itsu on December 17, 2020, 04:19:37 AM
Nick,
there are expensive differential probes on the market, but most modern scopes have a math function on which you can subtract (-) 2 channel signals.
That is what i use when mentioning the differential probe method.
As you have an analog scope there are differences, but this video shows how it still can be done:  https://www.youtube.com/watch?v=VWodjUSkYVE
Basically you use 2 scope probes without their grounding leads and subtract the signals from each other leaving the potential between them to measure, your signal.
Be aware that although not using the ground leads of the probes, you still have to watch out not to exceed the probe channels max. voltages.
Itsu
Hi Itsu
First time i see this technique! I can't wait going home and play with that!!! ;D ;D
Thanks a lot!!!
NickZ
Quote from: Jeg on December 17, 2020, 04:32:32 AM
Hi Itsu
Thanks a lot!!!
    itsu:
    Not sure if I understand the (-) that you can subtract from. Thanks for the explanation, maybe I will try that way, as well.I do have both an analog scope as well as a newer diglent SDS 1052DL digital scope.  I don't use the older scope anymore as it has some problems now, after all its years at the beach.
   I always use just the positive probe to test the circuits when dealing with HF and HV. Seems to work ok for what I need it for, as I am not working on systems with tiny outputs. I also use the one milimeter spark = 1000v for a visual comparison on HV.
   Perhaps Jeg can tell us more about the comparison, to just using the positive probe to test for HV 1000v to 10000v.
   NickZ
NickZ
   Justawatt:   As I understand it, the device he bought from Ruslan for $5000 did NOT WORK. It has a relay that needs to be connected to a power source for the device to turn on. Otherwise, no it's not working, not self running, even at 200v, as it is a fake.
Ruslan was taken to court about it, and suppose to have lost the case.
  This is all hear say, so...who knows what the real truth is.  But, that relay thing is enough for me to not believe what Ruslan says.
And Ruslan did say that he will not show and tell all, about the workings of his devices. So...
   NickZ
AlienGrey
Quote from: NickZ on December 17, 2020, 09:27:55 AM
   NickZ
Well last i know was he got it working, Talk to Wesley instead of doing nothing
AG
