Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Electrical Engineering: Ch 3: Circuit Analysis (29 of 37) NPN Transistor Current Gain
https://www.youtube.com/watch?v=EMFjY1cQGxY
Electrical Engineering: Ch 3: Circuit Analysis (30 of 37) NPN Transistor Current Gain Ex. 1
https://www.youtube.com/watch?v=NWqqsn6SZAY
Electrical Engineering: Ch 3: Circuit Analysis (31 of 37) NPN Transistor: Voltage & Base Current
https://www.youtube.com/watch?v=Q8QpPpFCoIs
Electrical Engineering: Ch 3: Circuit Analysis (32 of 37) PNP Transistor: How It Works
https://www.youtube.com/watch?v=S6KXhNYFDZk
Electrical Engineering: Ch 3: Circuit Analysis (33 of 37) NPN Transistor: Equivalent Model
https://www.youtube.com/watch?v=1LyChbpitVg
Electrical Engineering: Ch 3: Circuit Analysis (34 of 37) Solving Basic Transistor Circuit (MESH) 1
https://www.youtube.com/watch?v=hkDiSFq3DH4
Electrical Engineering: Ch 3: Circuit Analysis (35 of 37) Solving Basic Transistor Circuit (MESH) 2*
https://www.youtube.com/watch?v=LC-7tEE5fR0
Electrical Engineering: Ch 3: Circuit Analysis (36 of 37) Solving Basic Transistor Circuit (MESH) 1
https://www.youtube.com/watch?v=m8I_7kRkk8A
Electrical Engineering: Ch 3: Circuit Analysis (37 of 37) Solving Basic Transistor Circuit (Node) 2
https://www.youtube.com/watch?v=060xgad-9Mw
circuits :
thermalelectric
thermalacoustic
electrothermal
electroacoustic
unidirectional
reversible
dB gain/lost as ratio !
US5675306 Heaviside magnetic current ( Prof. Ehrenhaft )
https://patentimages.storage.googleapis.com/1d/16/05/f22acce223971f/US5675306.pdf   part 4
Related thermal noise/oscillation/vibrations :
Infrared radiation  in the electromagnetic field spectrum : nm
Astrofoil(TM) ,bubble-alu-foil,documents :
IR radiation has no temperature !  8) Brownian movement !
What is "temperature","movement" : from steady/motive point of view !?
color
The transistor formula only needs to remember this.
magnets we can get in thousands different manners,transistors also in many variants !
https://de.wikipedia.org/wiki/W%C3%A4rmerauschen
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/W%25C3%25A4rmerauschen
https://www.britannica.com/science/electromagnetic-spectrum
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Extremely_Low_Frequency
                                 atmospheric RF antennas,transistor incorporated
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2943189A&KC=A&FT=D&ND=3&date=19600628&DB=EPODOC&locale=en_EP#
https://worldwide.espacenet.com/publicationDetails/originalDocument?CC=US&NR=2813242A&KC=A&FT=D&ND=3&date=19571112&DB=EPODOC&locale=en_EP#
                                               amplifier
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=3&adjacent=true&locale=en_EP&FT=D&date=19940318&CC=FR&NR=2695768A3&KC=A3#
input :
The primary current is supplied by a small alternator (currently used to provide lighting for bicycles at barely 6 volts and Oa, 35 or an electromotive force of 2 watts, 15.
input power amplification process :
Our first work will therefore be to increase the amperage (more powerful therefore the greater electromotive force) torque n "1
We will therefore bring the winding of the coil 10 (inductor coil) to 9 meters by a nickel silver wire of 2 mm 6 in diameter, that is to say the section area of this wire of 5 mm 2 30.
The resistance obtained will be 0.49 (in relation to the fact that a wire 15 m long of nickel silver 2 mm in diameter and therefore 3 mm2 14 in section has a resistance of 1 ohm, 4).
The voltage being 6 volts we will obtain the amperage by dividing 6 by 0.49 which will make 14 amps or (6 x 14 = 84 Watts) instead of 2.15 watts originally.
This coil transforming the soft iron bar into an electromagnet, the latter will therefore be much more powerful and will provide the 2 "induced coil with a stronger induction.
By this low power process and output no refrigeration need !
For experimental prototyping and physical-scientifical "q.e.d." the first stage enough ! C.O.P 84/2,15 = 39
                                           Quantum-mechanics question and answer !?
https://translate.google.com/translate?hl=&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FQuantenfl%C3%BCssigkeit&sandbox=1
https://translate.google.com/translate?hl=&sl=de&tl=en&u=https%3A%2F%2Fde.m.wikipedia.org%2Fwiki%2FDe-Broglie-Bohm-Theorie
Sincere
OCWL
color
I appreciate the high-level mental world of lancaIV, but I don't think the long sentences here are very helpful.
