Color's Kapanadze forum, FE builds circuits and comments
Started by AlienGrey, February 03, 2019, 05:22:13 AM
color
Magnetic Resonance Amplifier 2: Exp1 Waveforms
2014. 2. 17.
https://www.youtube.com/watch?v=RdRDEhaLFSI
Transformers and grenade coils using the gate drive IR2110 can draw high voltages to the secondary coil, but the resulting severe heat generation in the transformer and grenade coils becomes even more serious when Tesla operates.
It is TC4420, which shows that Ruslan tried to augment the push-pull circuit to activate the IR2110.
In the existing power supply, IR2110(2A)/IR2113(2A) is a study seller class,
In the free-generator, the TC4420(6A)/TC4421(9A)/TC4451(13A) is the best seller. ::) 8)
color
PSU 24V-150W/6.3A.
The yoke-transformer primary coil is 10x10 turns and the secondary coil is 12x12 turns.
The MOSFET driver is TC4421(9A).
The picture below is a situation where the output-resonance does not work.
Only yoke-transformer self-resonant output is displayed.
The digital voltmeter dances in numbers depending on the situation.
Digital voltmeters cannot accurately measure due to resonance-propagation interference.
Analog voltmeters also have different metering needles in certain situations, but they have relatively less radio interference, so the results are recognized as analog voltmeter readings.
I predict the voltage from the brightness of the light I learned from experience.
The three methods are combined to predict the outcome.
Output-resonance does not work well if the winding of the primary coil of the output transformer is less than 30 turns.
Output-resonance works stably over about 50 turns.
Ferrite-transformers work better than silicon-transformers. ::) ::) ;D ;D
forest
I want to return for a moment to Tesla patents :
https://patentimages.storage.googleapis.com/62/90/92/45a5932052a940/US645576.pdfhttps://patentimages.storage.googleapis.com/41/ec/af/a57b4c65986fd0/US649621.pdf
in both the transmitter and receiver are oppositely wound. The same I found in Kapanadze replications. Would it be the secret to allow undisturbed resonance?
AlienGrey
Forest your PDF wont load, comes up with an error, if your north of the equator it's about coming and going like down the plug hole of the sink
the way the world spines. Are you giving or taking depends on spin.
forest
