Magnetic wheel by steel shielding
Started by vineet_kiran, February 02, 2019, 08:15:48 AM
vineet_kiran
Quote from: nix85 on March 20, 2021, 11:50:56 AM
First is imagined infinite vibration. A proto-mind filled with vibrations of infinite frequency, infinite amplitude.
This infinite vibration is bound by vibrations of limited frequency and amplitude creating interference patterns along 6 axis of time creating the illusion of 3D space.
Does fields also have natural frequency of vibration?  If so, what is the natural frequency of vibration of magnetic field?  If  you know this, you can simply resonate magnetic field with external frequency, keep a coil near it and generate infinite energy.
Floor
@LankaIV
I found it a bit difficult to grasp the fundamentals of this
method you posted.   http://www.rexresearch.com/gary/gary1.htm
Although much different than the   user GammaRayburst   presented design @
https://overunity.com/18511/floors-magnets-explained/dlattach/attach/175994/
It seems to me, that the fundamentals of the operations are the same in these two.
Am I understanding the www.rexresearch.com/gary/gary1.htm correctly in this
respect.
   regards
         floor
nix85
Quote from: vineet_kiran on March 21, 2021, 12:00:18 AM
I don't know it's exact frequency, but i do know it's a first child of Primary Light, so it's very close to it and thus extremely high. I doubt any macroscopic object can resonate that high but some nanostructures should (well, electrons do).
floor,
nix85 delivered Gary related magnetic force line and field related image ,but to think about there is the need to study the total description.
It is attraction/repulsion distance related, in Gary life era probably for most "engineers" something not as knowledge common !
Floor
No NET work is done against the magnetic forces in the two drawings.
It requires the same amount of energy to slide magnets apart as can be
gained from their sliding together.
But because the peak in the force to displace by sliding, the two magnets
away from one another ....
does not occur at the same time as does the peak in the force of the attracting of
the other two magnets, as they slide toward alignment one over the other.
Very difficult to arrive at a 0 work input against magnetic forces in this
arrangement.
Because the peaks and troughs are not in synchronization, substantial work
would be done in sliding the two sets of magnets between the two positions
illustrated.
It would otherwise require what ?
A complicated gear system to adjust the force to distance ratios of the motions,
so that the the curves match ?
In a momentum based motion context, the sets of magnets would alternate between
slow down and acceleration. Energy would be spent to over come inertia during the
acceleration.  But because the energy to cause deceleration is not captured in
favor of the momentum, the net worth, would be a loss of energy  / slow down.
