Bullet blimp.
Started by synchro1, March 02, 2021, 08:26:34 AM
synchro1
The difference between blade spacing and blade pitch angle is critical. The Cyclo rotor shell is not a propeller duct but prop pitch and spacing remain critical.
synchro1
This kind of coaxial gear can run the counter spinning rotor wing with one rubber band : The rear prop should have a deeper pitch to power the rotor wing. The front prop can help power the rotor wing with it's exhaust.
Lift is a factor of cubic meters of air over square meters of wing area.
synchro1
Removing the top and bottom of the Pepsi can but leaving a little bit on each end to support the rubber band and propeller would improve the flight distance and speed. Take note of the spiral twist in the fins.
synchro1
Nesting the propeller by ducting it inside the rim of the cycloidal wing would help. Simply recessing a stick frame inside the can and using a smaller propeller or moving to an Oatmeal container would work!
