Reactive Current - Parallel RCL
Started by nix85, June 01, 2021, 08:43:14 AM
0 Members and 27 Guests are viewing this topic.
nix85
For energy transfer to happen voltage and current must be in phase.
Reactive power means voltage and current are not in phase, energy bounces back n forth.
Resistance brings them in phase.
Exception is an antenna, voltage and current are 90° outta phase, yet it radiates.
They have radiation resistance.
https://www.youtube.com/watch?v=OuVQqFhualI
https://de.wikipedia.org/wiki/Thomsonsche_Schwingungsgleichung
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Thomsonsche_Schwingungsgleichung
oscillating circuit
E : magnetic field energy of the coil
E : electrical field energy of the capacitor:
Total energy of the system (constant)
how a circuit " becomes harvester/generator/converter" ?!    "imaginary/real" magnetic field "particles" and electric field "particles"
        magneton
https://translate.google.com/translate?sl=auto&tl=en&u=https://www.chemie-schule.de/KnowHow/Bohrsches_Magneton
        graviton ?
        https://en.wikipedia.org/wiki/Graviton
Thomson or Kelvin
https://de.wikipedia.org/wiki/William_Thomson,_1._Baron_Kelvin
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/William_Thomson,_1._Baron_Kelvin
condensator/capacitor and spring analogon related         maximal temperature and minimum temperature : 0°K(elvin)
bedingt das e-Feld das b-Feld,oder inverse  oder ist es nur "gedankliche Annaehrung" ? 1/2/3/4D ?
does the e-field cause the b-field, or inverse, or is it just ,the e-/b-field images,static "mental approximation"? 1/2/3 / 4D?
e-field : + to - orientation
b-field : cw/ccw spin (arrow) orientation
the two in one
https://upload.wikimedia.org/wikipedia/commons/thumb/1/16/Lorentzkraft_und_Induktion.svg/220px-Lorentzkraft_und_Induktion.svg.png
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Lorentzkraft
                                                            or Biot-Savart also Ampere also Laplace Force
natural particles  behavior or enforced being -in tube/in coil - "enclosed" and deficient in freedom degrees or (brownian/temperature) movement speed increasing cause (sub-)ion(-particle)-"wind shadow" effect (spin positive/negative ,neutral)
different particles and their polarisation (and MeV) lifetime !
air core versus solid core : movement ! ( Ether -GEDANKENPROBLEM : wave/light !  ::)  )
Resistance brings them in phase.  in Ohm,in Mho (or Siemens ),by RESISTANCE ZERO ?
  A/m finitum number ?
https://phys.org/news/2012-03-efficiency.html  "voltage decrease" is the boss here
Plancksche or Diracsche Konstante ! https://translate.google.com/translate?sl=auto&tl=en&u=https://www.chemie.de/lexikon/Plancksches_Wirkungsquantum.html
is the boss its number here : https://overunity.com/18878/reactive-current-parallel-rcl/dlattach/attach/181834/image//
They have radiation resistance. :o
"They" ? the device/s ? the "emissive/receiving" medium particles ?  L.A.S.E.R,M.A.S.E.R   : .... E.R.   ( P.H.A.S.E.R.)
" resistance " : electrical,magnetical,kinetical-mechanical ?
a bullit shoots out the pistol/gun chamber/channel  : in chamber phase velocity,outer chamber :
in air/solid medium ( bullit straight/rotative movement ?) ballistics
carbon : conductor or isolator ?
nano-carbon : conductor or isolator
carbon or nano-carbon on/off switch ? METAmaterial
Nano tubes internal a-/normal movement behaviour ? attraction/cohaesion (e/-, m/-) forces ?
decreasing Voltage and high A/m :
  http://www.rexresearch.com/kemeny/kemeny.html
A new electric circuit system for electric cars
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=20190328&CC=DE&NR=112017003611A5&KC=A5
Device for an electric drive for electric vehicles
                                                reactive-displacement current-circuits
nix85
https://en.wikipedia.org/wiki/Radiation_resistance
Unlike other resistances found in electrical circuits, radiation resistance is not due to the opposition (resistivity) of the material of the antenna conductors to electric current; it is a virtual resistance due to the antenna's loss of energy as radio waves.[2][1]
to radio conversion (resistance) losts
give me please an (near) 100% conversion principle !
Betz/Carnot cycle efficiency ( also valid for e.-m.-circuits ) : over this given efficiencies !
You can get high C.O.P. devices,but the efficiency factor <(theoretical limit same) =1  :
https://translate.google.com/translate?sl=auto&tl=en&u=https://de.wikipedia.org/wiki/Carnot-Wirkungsgrad
        eta
But 8)  : f.e. https://worldwide.espacenet.com/publicationDetails/description?CC=DE&NR=102010044865A1&KC=A1&FT=D&ND=3&date=20120315&DB=EPODOC&locale=en_EP
in using "forbidden "( non Physics ,algebra and geometry) "pure statistical/abstract " maths lessons formula its laws and order :
Bruch/Division : Divident and Divisor = Quotient  Divisor = positive number or negative number ,NEVER ZERO
                                                   simple calculator gives : SYNTAX ERROR ( forbidden ! Denied !)
                      When a number is negative than there has to be a cross point from negative to positve ,in time - ,in local distance)
in PHYSICS ZERO is the MIDDLE POINT from the XYZ Coordination-Cross,with movement from/to/cross ZERO
                                         Multi-dimensional  PHYSICS SYNTAX in formulas applying !
                                       We read even about "negative time " in Quantum-mechanics  !
                                                reactive and active current compact circuit,off-grid,self-charging
nix85
Like i said before, EVERYTHING RADIATES in almost all circumstances.
