Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 48 Guests are viewing this topic.
ramset
Lanca
My friend.... sorry to bother on your "date night" or Friday....
I have a question on this COP>5 cavitation system....
https://m.youtube.com/watch?v=Ji0GAt-q2EM
Your opinion?
I read in comments 100 years old tech ?
In your leisure time if you can find ? Good bad or ?
Hugs from the other side of the pond!!
Respectfully
Chet
Ps
Or anybody has info?
Thanks Grandma
Yes,I remark it !
And looked for this process !
Cavitation,superluminal/-luminous C.O.P. 5 ! ?
Cavitation Energy Systems,today to find : https://molecularimpactenergy.com/
https://www.prnewswire.com/news-releases/cavitation-energy-systems-files-landmark-patent-300104091.html
I will think and try to find an answer !
Sincere
OCWL
Good Morning,Chet !
I did a short archive review and refound something interestant,related "liquid heating" and C.O.P. 5 !
At first a possible finding energetic e-drive consume improvement :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=4&ND=3&adjacent=true&locale=en_EP&FT=D&date=19951107&CC=US&NR=5463914A&KC=A
Now the "heater" :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=19840110&CC=US&NR=4424797A&KC=A
The heating rate capacity of the liquid heater 25 is also dependent on the velocity of the cylindrical peripheral surface 66 on the rotor body 56. When water was used as the liquid to be heated, a velocity of about 1800 feet per minute generated about 19,000 BTU per hour whereas rotating the surface 66 at a velocity of about 2550 feet per minute generated about 25,500 BTU per hour. The volume of liquid in the liquid heater 25 and the system of the heat exchanger 12 and the liquid heater 25 should be such that the air passing through the heat exchanger 12 at a prescribed volumetric rate can be heated over the desired temperature differential. It is found that liquid heater 25 holding about one gallon of liquid with the system holding about three gallons of liquid is sufficient to heat air passing through the heat exchanger 12 at a volumetric rate of about 300 cfm about 40 DEG-80 DEG F. with a temperature differential in the liquid passing through the heat exchanger 12 of about 15 DEG-20 DEG F.
In the system illustrated, the diameter d1 is about 5.5 inches, the diameter d3 is about 4 inches, and the length L2 of the surface 66 is about 6 inches.
The drive motor 26 operates from a 115 volt power source and draws about 5.5 amps to rotate the rotor assembly 31 at about 2400 rpm to move the peripheral surface 66 on the rotor body 56 at a velocity of about 2550 feet per minute. Thus, the drive motor 26 has a power consumption of about 0.6 kilowatt per hour to produce a heating output of about 25,500 BTU per hour.
In the above system, the fan 15 was operated to force air through the heat exchanger 12 at a flow rate of about 300 cfm. With the rotor assembly 31 rotating at about 2400 rpm, the air passing through the heat exchanger 12 was heated from a temperature of about 60 DEG F. to a temperature of 100 DEG-145 DEG F. while the water temperature supplied to the heat exchanger 12 from the liquid heater 25 was at a temperature of about 210 DEG F. and the temperature of the water returned to the liquid heater 25 from the heat exchanger 12 is at a temperature of about 185 DEG F.
https://www.rapidtables.com/convert/power/BTU_to_kW.html  25500 BTU (x 0,293 ) equates  7,473 KWh
1981 filed ,now 2021 :  40 years +
https://www.whitepages.com/name/Eugene-Perkins/Dawsonville-GA?fs=1&searchedName=eugene%20perkins&searchedLocation=Dawsonville,%20GA
Less known in-/output ratio :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19950530&CC=US&NR=5419306A&KC=A
An apparatus which generates heat in liquids, which has no support bearings, shaft seals or any other mechanical friction points, which will never wear out or require maintenance of any kind, which is simple to understand and operate, which is simple and less expensive to manufacture, and which operates more efficiently due to its ability to generate useable mechanical energy is clearly and greatly needed.
Filed 1994 ,now 2021 : 27 years+
https://www.whitepages.com/name/Michael-T-Huffman/Seattle-WA?fs=1&searchedName=michael%20T.%20Huffman&searchedLocation=Seattle,%20WA
ramset
Lanca
Maybe we start a cavitation builders section (there is already interest ...reason for my plea to you for help! Open source Builders need higher vetting standard for ruling out deceit in claims ..prior to putting resources together !)...CES claim as you show has evolved ...
From this https://m.youtube.com/watch?v=Ji0GAt-q2EM
To this https://molecularimpactenergy.com/
As you have already shown in above posts ( additional info posted) some serious gains claimed
And some older claims too... seems odd nobody has gone anywhere
With such obvious anomalous gains ??
Honestly these claims are much simpler and within the ability of
Open source builders to verify .
Much gratitude
Chet K
Thanks Grandma
