Has anyone here constructed an overunity system that works?
Started by TriKri, March 29, 2021, 06:27:50 PM
0 Members and 49 Guests are viewing this topic.
kajunbee
I have a better idea. Why don't you build it and then you post your results on the forum.
ramset
I suppose I don't have the time you have to waste , nor would I waste the time of others so frivolously
Running into walls with hands full of tools is not a good plan!
There are thousands of open source builders, and each person has field of experience in their comfort
Zone ( tooling and ability)
I have done and shared open source cavitation experiments
LENR is very interesting field ( and plenty failures not shared )
Here a fresh look , hopefully with better thoughts and contributions.
Respectfully
Chet K
Thanks Grandma
kajunbee
If it's a waste of time then why ask someone else to do it. I don't have a great deal of time to spend on projects because I'm away at work for a month or more at a time. I have been away from home 3 weeks now on a job that's inspecting a tanker sunk by u-507 in Gulf of Mexico during wwii. At the most I may have 10 days at home before I leave again. There is a lot to catch up on once I do get home. But I do manage to spend some time and effort on some projects. But I do not ask others to spend there time and hard earned dollars on them.
ramset
Maybe it's my poor writing skills
Or language barrier?
You are saying same thing ( in my interpretation)
Here I suggest a discussion and investigation to establish veracity of project ( picking up the tools) and here I include myself as potential builder...
However I might have missed your point? ... seems you already see something "you" would build in above ?
Or ?
Respectfully
Chet K
Ps
Nobody has ever shown Repeatable LENR reaction ... EVER ( to science)more out than in ..
Some are dancing around .... but not yet !( regardless how many patents ( or claims)can be stacked on the table !
Vetting here is important ( who has true LENR gain mechanism!
Thanks Grandma
https://overunity.com/18884/is-output-four-times-the-input/msg558677/#new
https://www.flightliteracy.com/the-law-of-the-lever/#:~:text=This%20law%20states%20that%20a,about%20the%20fulcrum%20is%20zero.
https://worldwide.espacenet.com/searchResults?submitted=true&locale=en_EP&DB=EPODOC&ST=advanced&TI=&AB=&PN=&AP=&PR=&PD=&PA=&IN=norio+tsukihara&CPC=&IC=&Submit=Search
why so many ,different ?,applications,during 4 years ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=5&ND=3&adjacent=true&locale=en_EP&FT=D&date=19830729&CC=JP&NR=S58127557A&KC=A
citing documents :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=1&ND=4&adjacent=true&locale=en_EP&FT=D&date=20140924&CC=EP&NR=2782231A1&KC=A1
[0013]
Through the applications of the drive gear (1) and the transmission gear (3), the present invention is active by the Law of the Lever.
According to Fig.14 , P serves as the effort force, a as the effort arm lever, Q as the resistance force, and b as the resistance arm lever.
The formula is Pa=Qb, Q/P=a/b, thus, when the ratio of a: b is 10, Q=10P, the output power to the generator (5) would be 10 times multiplied, therefore increasing the amount of electricity generated.
[0014]
For example, assuming the teeth number of the drive gear (1) as 12, the transmission gear's (3) teeth number as 240, when performing the engagement turning, and the transmission gear's (3) power-multiplying is calculated by half of the transmission gear's (3) teeth number - 120, the output power would multiply by 10.
Thus, 20 HP of input power from the driving motor (2), the output power of the present invention would increase to 200 HP to activate the generator (5).
[0015]
Therefore, by simply adjusting the gear teeth ratio and power output of the driving motor (2) to fit the market's needs, the electricity generated by the present invention can selectively reach 50 kilowatts, 110 kilowatts, 150 kilowatts, 200 kilowatts, 300 kilowatts, 500 kilowatts, 1000 kilowatts, or even 2000 kilowatts etc.
[0016]
A First advantage of the present invention is that neither fuel nor energy supply is required when generating electricity once the multiplying mechanism is activated. A small part of its self-made energy would be recycled to drive the driving motor (2), which makes the energy produced by present invention become a green energy.
[0017]
A Second advantage of the present invention is that there is no area restriction for installing, which makes the present invention capable of being installed in the places with smaller areas then what is needed by conventional power generating facilities.
