0 Members and 23 Guests are viewing this topic.
kolbacict
And when the pendulum is at its lowest point, it pulls the large lever down.
The pendulum goes down too, and then it loses its energy.
The large lever drains energy from it. Therefore,
Milkovich himself says that his device is
not overunity.  I'm right ?
p.s. What if our pendulum will being swing in the plane perpendicular to the large lever?
but not parallel to the big lever, as we usually see.
Will this change anything in the parameters of the Milkovich double pendulum?
kratkaforma
https://www.protection-reputation.org/20041/sale-trapezium-grinding-mill-low-price-trapezium-grinding-mill.html
https://cycling-fitness.cz/2019/12/30+33628.html
https://nicedeco.nl/plant/2087-Jan-24.html
https://www.darmounia.pl/28105/CW3k6-Jan-1970.html
https://sunvillage.pl/news/2005-May-23_5858.html
https://aialusa.es/iFWeTkqI/23_european+type+trapezium+mill+23082021.html
https://www.energieholzbau.ch/machine/01_30220/
https://bulwary-augustowka.pl/stone/2003-21_Aug_21.html
https://e-business.edu.pl/gypsum/Super-Fine-Barite-Roller-Mill-Scm-3512/
https://antakalniopanorama.lt/ethiopia/2021_3323_Fri.html
https://tntmr.pl/mining/3795_2021_16/
https://projektlepiej.pl/27320/grinding-mill-gypsum-maintenance.html
https://www.ubytovnapodomi.cz/2014-Sep-29/Sat_11332.html
https://kreaktywni.pl/mining-machine/9t41ukx6/compound.html
https://www.ciptu.cz/3389/fXyIf2.html
https://www.wczasygaski.pl/copper/Feb_1829/
https://www.poitiers-palestine.org/8c4l0oaa/grind-mill.html
https://www.jmk-opakowania.pl/granite/2021-322/
https://arw-remonty.pl/dolomite/2021-May-5/2876.html
https://agatowcy.pl/mills/2021-May-24/3763.html
https://www.quillingstudio.pl/27962-line-mtw-grinding-mills-supply.html
https://www.marbox.com.pl/calculation/Mar/3909/
https://gastro-chef.pl/16494/jaw_12.html
https://www.paires.pl/May/30-7321.html
https://www.topintown.co.in/2020_Mar_17+5984.html
https://www.boulangeriepatisseriecoquilleau.fr/Feb_09-3119.html
https://marchedesvins-taninges-74.fr/grinding-mill/qh7u23ni/yfm.html
https://www.riverband.be/18684/2018-Jul/Vg4Gy1
https://www.rhythermining.com/products_category/milling-and-classifying/
https://sfighter.pl/powder/Feb_1773.html
https://hofkreatywnybutik.pl/12418/stone-milling-mining-grinder-mill.html
https://www.piekarniapeterek.pl/tcmming/13606.html
https://lachampagniere.fr/mill/Aug_18/7543.html
https://edukariera.pl/process/Jul_2129_Tue/
kolbacict
A pendulum was installed, oscillating in a plane perpendicular to the main lever.
The swinging pendulum pulls the end of the lever(bearing) in the swinging plane of the pendulum to the right, then to the left. If these forces are applied in a plane along a large lever, as in Milkovich's device, this is not visible, because there is great rigidity.  An interesting observation. ;)
