Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
Ufopolitics
Hello to All,
I do have to disagree with some comments here...as I agree with others.
First, thanks PmgR for the video link, I will take a look later on...
1- I do not believe this way to switch Coils is barely done by a simple ON-OFF kind of deal...otherwise it would not, definitively not required to have so much sophisticated electronics to do just a simple turn on/off like a wall switch.
Like I have said before, there must be an "attenuation" in  between on-off's, meaning a "fading on and a fading off" effect, in order that BEMF would be considerably reduced.
I also  said before, that if we get these signals in a scope (signals sent to rotor(s) coils, they will NOT be typical spikes, nor any square wave with steep ups and downs....and more likely they will look like a "Chopped Pyramid" with a flat top, which is the coil's full DC feed and therefore, full magnetic field exposure.
I will load an image (that I had to recover from an old account about ten (10) years ago) of a comparison between all three waves...and some call them "sawtooth waves"
I know this may sounds like "fiction" but it is not...believe me.
2- Related to Magnetic Fields Spectrum properties...please, let me remind you that magnetic fields are completely "Spatial" and linger around steel cores and copper, but further away in  space than any solid mass...as also (and very important to know) that whenever you turn off a coil, by cutting its supplied currents and voltages to zero...there is, still, lingering around space...that magnetic field in Space, not referring here to "domains on steel still aligned and still present...NOPE!!...I am referring to Spatial  Field, just like a ghost.
And this could be clearly verified with many new, state of the art techniques to "see" magnetic field spectrum...and NOT referring to the BS ancient type of using some steel shavings on a piece of paper.
I am talking about CRT Viewing, Magnetic Film viewing and Ferrocell viewing of the Real Field Spectrum.
Therefore, if we review AGAIN, 1 & 2 above...now let's apply some speed to the fractions of a millisecond, nanoseconds speed...then we will get the desired effect of seeing these fields transfering, jumping from one steel core to the other, without interruptions.
This is exactly the effect we need to achieve to obtain the great output that NO transformer, No Generator could ever perform.
And I will go to another post to discuss about Coils BEMF... cause I do not want to make them too long, but precise and  to the point.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
                                             https://engineeringlearn.com/wp-content/uploads/2021/08/Lever-1-1024x539.jpg
                                             https://www.fluke.com/en-us/learn/blog/power-quality/power-factor-formula
                                                         "  -1             /0/            +1            Power Factor  " -Balance
                                                         -100 %         0          +100 %
                                                        BEMF       FULCRUM     EMF
        ETA  IDEAL :   net-grid electricity provider
                                                              +100%/  -100% = 1
        ETA             IDEAL off-grid > IDEAL net-grid
                                                              +100%/  -  50% = 2
                                                              +100%/  -  25% = 4
                                                             +100%/   -  20% = 5
        BEMF     ETA
                                                             +100%/   - <20%= >5
                                         ergo :   battery/capacitor sourced circuit
                                                     or : one-way -/bypass -/filter- circuit
wmbr
OCWL
Ufopolitics
Geez, it's been such a long time ago...
About BEMF in a Coil...my take, my research since 2012...and before...dating back to 1996...when I started my first Patent application about Motors-Generators of a different configuration...and yes, it was granted in 2000.
There has been a way to "capture" Coils BEMF in a very simple way...and by now, there are many electronic circuits which play with similar design scenarios.
My Motors designs got me to discover this way to do it...and so, I have started a Thread in Energetic Forum, and thanks God is still there...back in 2012.
I simplified that circuit in a short image, that I have used as my Logo, for many years up to  now...I will upload it here.
Point is, I have conducted MANY, MANY Experiments, which proofs ALL I am saying here...Ahh, thanks we have YouTube!!....and those videos have a "Time Stamp" that absolutely no one, not even me, can change...to set time backwards...
Now, because this BEMF captured does NOT behave like "typical" Hot Electricity...as it moves MUCH MORE faster, as it does not cause the same "lethal" effects as HV/HA Electricity does...I called it "Radiant Energy"...or Cold Electricity...
In 2012 and further on, I conducted several experiments with this type of BEMF collected...or Radiant Energy, for example on video below, I used a specific and simple 555 timer with FET's  that I built -from scratch- to drive a single coil...set Diodes the way shown on  my Logo...and collected from the Blue side this Special BEMF, or Radiant Energy...and was abale to light a CFL Bulb (remember at that time they were still figuring out how to make Powerful LED's, but not available then...LOL
I added resistors to FULLY SHORT the Lamp circuit...and nothing happens...not even "warming up" the resistor....and you perfectly well know, than in "conventional" hot electricity, this resistor would have burnt right away...plus lamp will stop lighting.
Point is, that BEMF could be "manipulated" the way we desire...whether to store it (in special capacitors, any conventional Electrolytic Cap will blow up if you try....and I did... :) or do whatever you wish with it...
Video from 2012: RADIANT ENERGY/ COLD ELECTRICITY TEST 1 & 2
Ufopolitics
―Leonardo da Vinci
Floor
Qoute from Ufopolitics
"Like I have said before, there must be an "attenuation" in  between on-off's, meaning a "fading on and a fading off" effect, in order that BEMF would be considerably reduced."
End of that quote
Agree...
The speed of motion (field expansion and / or collapse) is always a factor in the voltage induced.
Ufopolitics
Any one of You Guys, are familiar with Clemente Figuera's Generator from 1908?
Figuera found a way to do this same, exact scenario, but by using a specific (it is said he had it made in Germany, back then) a Mechanical-Electrical Driver...
Well, I built that driver (still have it, and runs beautifully) as also experimented for a long time with different setups (videos available  on my Chanel)...and even went further in the design of the cores...
Figuera used resistors in between commutation changing plates contacts, and it was basically to achieve that "Attenuation Effect" on the coils...so, it was not abrupts, steep, radical turning Off-On's...
Now, when I see this newer images of Holcomb's design, where we have TWO Virtual Rotating Rotors, one outside and one inside, "sanwhiched" with the Generator Coils-Cores in the middle...it immediately remind me of my previous concept...back in 2015-17...that I am uploading here...
Cheers
Ufopolitics
―Leonardo da Vinci
