Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
pmgr
Ufopolitics
Quote from: bistander on April 05, 2022, 05:37:21 PM
Ufo,
Scroll down that link you give and click on the path to this:
"Synchronous Generator Working Principle"
Read there and you will see the author refer to the rotating magnetic field produced by the stator, armature in this case. Quoting him, or her;
"The stator currents produce a rotating magnetic field in the airgap of the generator that rotates at synchronous speed. In essence, the generator has two rotating magnetic fields, one due to the rotation of the rotor field and one due to the MMF of the stator windings."
bi
Hello Bistander,
Yes, I read that, Thanks, but I knew that...it is the Magneto Motive Force (mmf) which is present whenever the Induced Circuit is closed by a load, So currents are flowing...it also takes place in Single Phase Generators, in motors...and all electromagnetic circuits.
However, notice the Inducing fields are DC?...the same old single bulky coil rotating DC Magnetic Field Circuit...
And that mmf generated at Stator when loaded, is just a consequence from main DC Rotating Field, so, of course it has to be in sync!!, if it is just a result, a consequence from the RPM's developed and Induced EMF by Rotor.
Related to the previous 3 Phase #1 Generator that I cited before...note it works (as Inducer) with a 3 Single Phase Lines (Not 3 Phase) wound spatially apart by 120º...so, the Rotor is configured to induce Stator Fields with the 120º "time stamp" sequence in a 360º spin...
On my concept, my testing, it is way more viable, simple and easier to use the typical DC Two N-S Poles Virtual rotation of the Field, than using 3 single phase...I mean, we could get DC power out from a SuperCap, a Battery, a PSU etc,etc...to generate that field...
But anyways, much appreciated your help here.
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pix
Ufo,On the picture you have your permanent magnetic field rotating (permanent magnet for clarity) .
And three coils 120 deg apart.
As a result you will have  induced 3 sinusoidal signals in each coil, phase delayed by 120 deg.
Now.
Reverse this process.
You will have your DC magnetic field rotating.
Pix
Ufopolitics
Quote from: pix on April 06, 2022, 10:36:21 AM
Now.
Pix
@Pix,
Thanks, I do understand what you and Bistander are explaining, believe me, very clear...
But "reversing this process" brings more complications, as I do not want to involve (for now) any input from main 3 phase ...can you understand my point?
For me it is way easier, to start demonstration with a DC Constant Rotating Field...just one input, plus and minus, and just two poles, North and South, simple.
As for those that want to try using electronics to do their switching, it is also easier, much more easier, to start with simple DC Input, that could be switched easier and cheaper, than trying to make a Three, out of phase, smooth sinusoidal signals...
It is about to "prove a concept"...and to make it as simple as posible...for sake of understanding by all audiences.
Thanks again
Ufopolitics
―Leonardo da Vinci
marcosbk
agree with you UFO,here are drawing that i also posted on energetic forum same time when i posted here...
to me looks like may give something and I don't see what is against  the books...
sadly, for me will take a month till i can test but I will follow your work closely.
