Permanent magnet assisted motor coil designs
Started by captainpecan, January 24, 2022, 02:35:06 AM
seychelles
seychelles
PLUS COIL WINDING MONKEY CRAZY IDEA. COIL WITHIN COIL.
captainpecan
Quote from: seychelles on April 12, 2022, 06:51:15 AM
I MEANT THIS BELOW.
Yeah, I was considering wrapping the magnet with 1mm sheet when I was looking for the right size bushings. I found these to try, and have just not tried the other yet. About the way you suggest winding it. I have been kicking around some ideas to try in the future. Some ideas have been flowing between floodrod and I on his post as well. Haven't tried these yet. I'm trying to wrap my mind around the best ones to test because each is a special wind. I may consider the 1mm wrap with ferrite magnets like your earlier suggestion to be able to use way less wire to test each coil and maybe easier see changes. I do have a scope to see minute changes although I need more experience  with it. Keep thinking through what tests you would be interested in seeing. I will try and work on some soon to learn more about this.
Quick question though. So I understand the thinking behind the winding you suggest here. It looks like a simple bifilar wind. Same direction. Both wires perfectly in parallel. What are you looking to test here? Interaction of the flux of the two wires, or simply same amount of turns but less resistance to allow more current to flow? If that's what you are suggesting, its a great idea because I can easily flip the windings to series to draw less current and add resistance for simple testing of the circuit. Am I on the right track with the thinking?
seychelles
FLUX LINE COMPRESSION. STRONGER ELECTROMAGNETISM. MONKEY
REASONING.
seychelles
TESTING THE ELECTROMAGNET YOU DO NOT NEED AN
OSCILLOSCOPE. BUT A CHEAP ELECTRONIC SCALE.
PLUS THE STUFF THAT MONKEYS DO NOT HAVE IMAGINATION.
