Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
nix85
I was clearly referring to caps for the tabletop device i talked about few pages back
when i said how weird it was 3uF caps are so small, now we know they are 0.1uF.
Those caps are clearly labeled DC which does not necessarily mean they are for DC only.
For example many polypropylene big caps "DC link caps" are labeled DC because that is their use
to smooth out pulsed DC; but of course they can be used for AC as well.
I know well about the dimmer, i seen all Don's lectures dozens if not hundreds of times.
Obviously, LC is AC...................or is it....
I designed this myself without seeing it anywhere
I believe i later saw a similar circuit once, i'm sure it exists cause it's so simple.
In any case it is a pure DC (through an inductor) LC tank.
(Sure pulsed DC is also AC, but it's clear what is meant).
Vortex 22
Quote from: nix85 on May 10, 2022, 03:14:58 AM
I guess this is a good time to remind of some basic formulas
wavelength = c/f
f = 1/T
a = v/t
momentum = mv
Kinetic Energy ke = 1/2 mv²
centrifugal/centripetal force: F = mv²/r
Force = Mass * acceleration
Work = force * distance moved  unit: newton meter or joule or Work = Mass * Gravity * Height
Work = Change in Energy
Power = work / time = force * displacement / time = force * velocity
Power (hp,watt) = work(ENERGY)/time aka time rate of energy transfer
Energy = Power x Time
XL= 2πfL
I= V/XL Alternating current flowing through inductor is applied voltage / inductive reactance
XC= -1/2πfC
Z = sqrt(R² + (Xc - Xl)²)
I = (V-E)/Z current through transformer primary E = voltage drop across primary inductance
F = 1/6.2832√LC
F = 1/2π√LC
C= 1/4π²Fr²L
Fl = R/2πL cutoff frequency of RL low pass filter
Fc = 1/2πRC cutoff frequency of RC low pass filter
ohms law: V = IR
power per second:
P = IV
P = I²R copper losses
P = V²/R
P=VI*PF true power (V and I are average, RMS)
energy stored in an inductor E = LI²/2
energy stored in an cap E = 1/2 QV = Q²/2C = CV²/2
for capacitor and inductor circuit V=IZ
for capacitor circuit V=C*(dv/dt)*R
I = C dv/dt current through a cap
1 Volt = 1 Joule/Coulomb
1 Watt = 1 Joule/Second
1 Ampere = 1 Coulomb/Second
V × A = J/C × C/s = J/s = Watt
electric energy E = IVt and E = (V²/R)t
1F = 1C / 1V - amount of electric charge in coulombs that is stored per 1 volt
C = Q / V and C = kA/d
E = F / Q electric field (N/C or V/m) is force per charge
F = qE + qv x B lorentz law, em forces on a charge
R = 80*pi^2*(L/W)^2 rad. res. of antenna where L=length of antenna, and W = wavelength
t = L/R inductor time constant, after ~5t (transient time) current reaches 99.5%
t = RC for RC circuit, after 5RC cap is 99.5% charged
transformer size is proportional to B MAX =V/F
in alternator emf leads flux by 90°+
energy content of wave is proportional to the amplitude squared P = E²
Z = sqrt( L / C ) cable characteristic impedance
reactive load temporary stores energy, not waste it (unless PS cant take it back)
v = L(di/dt) BACKEMF from an inductor
Short circuit current = V / alternator internal resistance
V=--N*dΦ/dt voltage farraday's law
V = BLv farraday law for moving conductor
flux density = amper x turns x core permeability x core area / m² (T)
F = ILxB force on a conductor in a magnetic field - laplace
as load increases, current in the conductor must increase to balance the forces: I = F/BL
free space impedence 376Ohm
C = 1 / sqrt permitivity x permeability of space
Hello
We can't explain what is going on in Don Smith circuit with mainstream as your basis.
If you could people all over the world would be replicating Tesla! Free
energy as we mistakenly call it would be the norm.
nix85
Quote from: Vortex 22 on May 10, 2022, 11:05:59 AM
Hello
You are mixing apples and oranges, all here know well conventional approach is no
solution to Don or overunity in general, but these are just some useful basic electronic
formulas which apply perfectly.
Vortex 22
ALL of Smith's devices lead up to a capacitor or bank
of capacitors, which – in a brilliant stroke of creative insigh
Vortex 22
I know, we all know this!
The basic idea :
How to make an electron captor?
In the suitcase device around 28.8 kw output
I can see with my eyes two electrons captors?
The small electron captor is powering the bigger one?
