Just another Don Smith thread
Started by nix85, April 11, 2022, 10:54:51 AM
Vortex 22
Quote from: whitelightningwizard on May 13, 2022, 08:52:51 PM
Mr. Vortex,
never built Don's pancake version because sec had more turns than pri. clear case of voltage step-up, which makes finding diodes trickier.
also look at frequencies Don specified and check w/ mind if this makes sense ?
like Zilano we need to use coils to lower working voltage so parts involved r cheap n readily available. we can step down voltage w/ caps alone also.
capacitor transformer.
wlw
Honestly, I never try it before
But In my simple opinion:
I can find one input source only in this coil Captor circuit?
Can this coil capture free electric charges? The answer is No
My guess
Even no second input source we have here?
No free energy in this setup !!!
No magic about that circuit!
Vortex 22
But after some minor changes
It will produce OU, I have no doubt about that !!!
nix85
Don said 14KHz was "enough to make a dent in things".
Practice shows even 50Hz is enough.
Get yourself 10kg of ferrite rods or if you can afford permalloy (hopefully you don't get
scammed like me), nanoperm, metglas or similar material and start playing with
resonance in comb with scalar (non-inductive coils)
That is the best advice anyone will ever give you.
nix85
Here is a quote from Miguel Serrano, let's call him a priest of esoteric hitlerism
Irrelevant, point is he was up there with nazis, he was kind of an insider.
And this is what he says..
"I have spoken with some ex-combatants of the SS who were on the Russian
front and through the final offensive in the Ardennes who saw mysterious weapons
in action that disintegrated enemy airplanes in full flight, lightning that left only a
space where a tank had been before
, or that paralysed the enemy without killing.
They were used only once and then disappeared."
This goes in line with the rumors Vladimir Terzinski heard that planes of admiral Byrd
down in Antarctica were hitting invisible walls exploding in mid air, almost certainly
nazi bases' forcefields.
nix85
Again, ask yourself what exactly happens in resonant parallel RLC.
How is current amplified but res. freq. is not changed.
Bigger current circulating in the tank should mean cap gets charged
faster. But it does not.
One might try to draw a parallel to a pendulum, adding slight push at
proper time makes amplitude of oscillation gets bigger but frequency
remains the same.
https://youtu.be/0W-EUVhqv98?t=290
But this does not really explain it.
Again, bigger current circulating in the tank should mean cap gets charged faster.
No one can answer even such basic questions, not to mention that power
amplification in parallel RLC is forbidden by the convention yet well known
and unquestionable phenomena. According to convention current is
amplified "at the expense of voltage". And in series RLC supposedly
voltage is amplified "at the expense of current". Total lies.
