Primer field overunity device.
Started by Jimboot, May 20, 2022, 08:58:05 AM
Jimboot
new bowl made but i think I'll need two for it to work. It fires the PM through ok but have not compared with the other bowls.
Jimboot
Still working on this and testing various configs. Lots of printing and sore fingers. With the PMs on the wheel this close it will freely move through both bowls. However because it is balanced equally between the bowls, in this config it has the same issues as say the HoJo . However this is just one config and there are a lot more to try.
citfta
Hi Jim,
Great workmanship as always from you.  Looks good.  Have you tried it with fewer arms.  I am thinking (dangerous thing to do) that the first arm needs to clear the second bowl before the second arm enters the first bowl.  I hope I  made that clear.
Take care,
Carroll
Jimboot
Thanks Carroll,
I've tried many combos and I've seen enough to know it has promise. STill more testing to do but I'd like to move on to using the 9.5mm pms as the shuttle now. I'll be starting with only two on the flywheel. I wanted to test the smaller PMs 15mm apart first. That itch is now scratched :)
Jimboot
