Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
matu
Hola a todos.
No sé si entendí bien el concepto, pero creo que lo que hace el sistema Holcomb, no lo hace un sistema trifásico convencional, ya que si bien es cierto que el sistema trifásico, crea un campo rotatorio bien difinido, no produce "ARRASTRE" de electrones en las bobinas inducidas, ya que va cambiando de fase a cada paso, Holcomb avanza paso a paso, pero llevando energizadas en todo momento al menos cuatro bobinas con el mismo polo magnético, por lo que a mi entender si que produce arrastre, que eso sea el motivo de la sobreunidad ya no lo tengo tan claro.
Saludos
Hello everyone.
I do not know if I understood the concept well, but I think what the Holcomb system does, does not do a conventional three -phase system, since it is true that the three -phase system, creates a well -diffused rotary field, does not produce "drag" Electrons in the induced coils, since it is changing from phase to each step, Holcomo progresses step by step, but carrying at all times at least four coils with the same magnetic pole, so that in my opinion if it produces drag, which, which That is the reason for the envelope I am no longer so clear.
Cheers
bistander
Hi Ufo,
Do you frequent OUR.com? Some very good threads, posts and members over there. Recently member F6FLT posted a reply to a newbie which I would like to share.
"Of course we can laugh when this well-known and completely conventional banality is brandished as a discovery.
Unless you think you're smarter than everyone else, which is unfortunately common because of the Dunning-Kruger effect, tell yourself that if you have a simple brilliant idea in a hackneyed field like electromagnetism, hundreds of thousands of others have had it before you in the past, that the idea is just the result of your own ignorance of the field, and that if it's simple, it's not brilliant at all but wrong. So if you really believe in it, at least make the effort to study and experiment first, rather than bothering us with useless childishness.
So Ufo, carry on. I'll be standing by waiting for proof, or at least convincing evidence.
bi
rakarskiy
The U.S. Patent Office received strong evidence for the examination of Dr. Robert Holcomb's patent and, as I understand it, Park Jae-sung's patent US8629588B2
or conducting an examination means nothing, and skeptics continue to argue that this is impossible.
Beginners Mind
Hello!  Thanks to all of you who give your time to participate on this thread, which I follow closely.  I have carefully studied Holcomb Energy System's website, all their videos and the pertinent patent.  There is a mystery perhaps someone here can solve.
For those who have studied the patent and videos, you have noticed a significant discrepancy between the "rotor" geometry and winding pattern in the patent and in the videos.  Attached are two drawings from the patent showing similar winding patterns and two pictures from the videos of their present rotors, which do not conform to the patent.
The patent drawings show narrow salient poles with coils wrapped around each individual pole.  Yet the "rotor" windings in the videos span multiple rotor teeth and, as can be seen in the top view, the salient poles resemble typical rotor teeth rather than long, thin salient poles.  Coils are clearly not wound around each individual salient pole.  The bottom view is particularly mysterious in that it suggests a winding pattern that repeats every 3 teeth.
The patent describes sequential DC switching of individually wound coils to create the rotating magnetic fields.  If HES is using DC switching with the present windings, they are not switching individual salient poles as described in the patent.
Can anyone deduce a winding and switching pattern that conforms to the pictures of the current rotor, particularly including the bottom view with 3-tooth repeats?  Thanks for your help.
Beginners Mind
Pictures referenced in previous comment did not attach.  Here they all are.
