Did someone tried to replicate a Hendershot Generator ???
Started by robbyd, August 19, 2007, 10:33:56 AM
Skysabre
Thank you, rc3po !
Thanks for the lead...There's a wealth of material to harvest from! I should have joined this forum a long time back! ! !
I'm inclined to pick on projects that can be done using basic materials and components. Maybe we can all use our know-how (mine is zero, but I have time ;D) to design specific components into a chosen project, and those with time and resources can start work. Maybe like a team effort?
Whatever you decide on, that's okay with me.
Finally, THANKS! for a lot of things.
Skysabre
Skysabre
Quote from: andrea76 on April 30, 2014, 11:25:42 AM
excerpt "from the archive of lester hendershot":
"A very small unit composed of wire, a magnet, several especially designed coils, condensors, collector units, and a few other minor items, will cut this force.  ANOTHER ESPECIALLY DESIGNED MECHANISM WILL POLARIZE IT, GIVING A POSITIVE AND A NEGATIVE CONNECTION TO ANY RESISTANCE AND THE RESULT IS THE GENERATION OF ELECTRICITY."
we forget something???
Hi andrea76
If you have any ideas to run this experiment further, please let me know. I haven't taken apart my unit until now, I'd be glad to mess it up again. ;D
Skysabre
rc3po
A/C doesn't have a positive & negative...
Forget it - it doesn't work and never will. You are wasting your time with the hendershot generator.
I have proven that it is a hoax. If it actually worked, I would be dancing a jig and going to collect my
million $$$.
benfr
I have no idea of what is missing for it to work, of course. But  I was wondering that since resonance with air coils happens or disappears when the coils are moved in relation to a ferrite rod ...
so if I had built this machine, I would not only move the iron rods away from the magnet to see  what happens, but also for debugging purposes, try to have the coil around thoses 2 iron bars movable in and out also. (sliding)
As I think the hendershot generator is something about resonance...It would may be allow to see things about resonance kick in.
Note : I also believe the inductance values and capacitance values are key in this machine, so ideally if that could be made to be variable somehow... may be we could make that machine work more easily...my 2 cents really...Cheers !
