Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
pix
Quote from: rakarskiy on January 09, 2023, 06:02:14 AM
Why do you think so?
In a synchronous generator, the excitation field and the phase field add up, no matter the winding wires in the groove or on the rods in the coils.
And you still not get OU ? :o
Why I haven't seen any OU synchronous generator? And I  worked with a lot of them.
Excitation coils work the same like rotating magnet,  AVR by controlling current to excitation coils, precisely controls voltage in the stator windings in the varying load conditions.
If your theory would be true, then we wouldn't need any engine burning fuel to rotate that generator, and increasing fuel consumption when load on the generator rises.
Cheers,
Pix
Ufopolitics
Hello to All,
I really can NOT understand WHY is it, so hard to understand, that by just rotating or displacing the Virtual Magnetic Field We all could have Excess Energy?
Any Rotary Electric Generator, whether 1, 2 or 3 Phase is SELF CONTAINED, SELF EXCITED, meaning, it is NOT REQUIRED, to be connected to absolutely ANY EXTERNAL SOURCE.
And so, -with that main part in mind- the only requirement for these Machines to Operate, is to Rotate the Exciter Field along with the massive Steel and Copper Rotor Assembly...
The Higher Percentage of Higher Opposition, to this simple Rotation Operation (or as also called "Reverse Torque") is caused by the PHYSICAL LENZ, reason why, we need the "Herculean" Diesel or Gas Engines with such heavy Torque while keeping a steady RPM, whenever being LOADED.
Now, on any Virtual Spinning of the Magnetic Field Device, like the Holcomb Energy Systems, that PHYSICAL LENZ is completely GONE...NO MORE THERE!!...BYE!!
And such "Missing previously required Constrain" is now "a thing of the past" on these Systems, just because it would automatically:
DEDUCT, SUBSTRACT, ALL HUGE ENERGIES AND MASSIVE SPENDITURE REQUIRED, TO RUN THE HERCULEAN DIESEL OR GAS ENGINES!!!
SO, ALL THAT NOW "SAVED" HUGE ENERGY PLUS MASSIVE SPENDITURE IS NO LONGER REQUIRED AT OUR INPUT...CAPISCI?
It is SO SIMPLE MATH, AND COMMON SENSE, that really, any average smart brain, could understand it very easily.
So, I believe, IMHO, We all, do NOT need to get involved/engaged, into such heavy and deep arguments about Math Formulaes, B-H Curves, and the works, to simply understand what is going on here...
Or is it just to create "confusion" in the understanding?!...Because I have completely ZERO CONFUSION to "digest" this simple Method(s).
Just my opinion...
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
pix
Quote from: Ufopolitics on January 09, 2023, 08:51:41 AM
Hello to All,
DEDUCT. SUBSTRACT, ALL HUGE ENERGIES AND MASSIVE SPENDITURE REQUIRED, TO RUN THE HERCULEAN DIESEL OR GAS ENGINES!!!
It is SO SIMPLE MATH, that really, any average smart brain, could understand it very easily.
So, I believe, We all, do NOT need to get involved/engaged, into such heavy and deep arguments about Math Formulaes, B-H Curves, and the works, to simply understand what is going on here...
Just my opinion...
Ufopolitics
If that would be true, then any "virtual rotating magnetic field", for example  3 coils spaced 120 deg and driven from 3 phase VFD would give "no physical Lenz"  to nearby coils and generate "free enargy" in them.
Lenz law applies also to non-physically rotating armature.
Any change in magnetic field causes in the other coil EMF that produces magnetic field opposing that change.
Cheers,
Pix
kolbacict
Quote from: pix on January 09, 2023, 05:38:55 AM
Typical trap where "free energy enthusiasts" fall.
When they think that hysteresis of ferromagnetic material is the source of free energy.
I also like the free spinning virtual magnetic field version better.
And if we could spin this field faster than the speed of light, maybe a miracle would happen at all? :o
з.ы.
.CAPISCI?
Capisco :)
vorrei credere.
Ufopolitics
Quote from: pix on January 09, 2023, 09:10:55 AM
First, just "3 Coils apart by 120º" would NOT have enough RESOLUTION to obtain a substantial and Solid Rotary Sequence, that would produce excess energies.
Yeah, like Transformers...correct?...well, that "PHYSICALL LENZ" is NOT there...just the Currents increase is present.
Cheers,
Pix
Correct, however, if the Exciter Field, or the "Primary", or the Inductor, is not "physically" moving, then the Physical Lenz becomes just a high pitch "Humming sound", which does not affect -at all- the Ouput Performance of these Machines.
Really Guys, it is very easy to "digest" these facts...However, it is entirtely up to you to do so, to accept it...not up to me, to explain it more clearer than this.
Ufopolitics
―Leonardo da Vinci
