Holcomb Energy Systems:Breakthrough technology to the world
Started by ramset, March 14, 2022, 11:07:24 AM
bistander
Quote from: SolarLab on January 17, 2023, 11:53:29 PM
See this link regarding how the pulsing works:
https://overunity.com/19069/holcomb-energy-systemsbreakthrough-technology-to-the-world/msg572781/#msg572781
I can not answer yes or no to whether you understand the diagram or not.
Timing was taken from the patent for the CAE analysis simulation proof-of-concepts. Results are shown
in the links provided.
If you want to argue about the nomenclature, etc. - forget it - I'm not interested and don't care!
SL
Hi SL,
Yes, I understand, in accordance with conventional science.
Ask Ufopolitics if he does.
bi
Ufopolitics
Quote from: bistander on January 17, 2023, 12:05:11 PM
Hi SL,
Please confirm that I am understanding your sequencing the way you intend it to operate. For reference, I attach a cropped image of the sequence drivers and coils from your diagram linked in the quoted post. You have 8 coils, 8 drivers, one coil per tooth and 4 teeth per pole and therefore 2 poles. The top 4 coils are only pulsed in the shown polarity such that the top pole, using coils 1 - 4,  will always be North. And conversely, coils 5 - 8 on the bottom pole will always make that pole South. Am I reading this correctly?
If so, this is a significant departure from Holcomb's description of sequence found in the patent application for the 16 tooth 2 & 4 pole rotors (circular). I do not believe the method represents a linear version of the RMF (Rotating Magnetic Field).
If in fact each pole does not swing polarity (N to S to N to S ...) then there are implications seen on the B H curve.
Your comments would be appreciated.
bi
I really do not see that much of a "wow" here...by the fact that LinGen does not swap polarities...
Figuera did it like that, way back in the 1900's...except, He did not have the LinGen "Stairs like" setup, with just two cores, but He arranged the electromagnets next to each others, in separated groups, having separate cores for each pair, however, still facing each others (Inductor-Induced) but, ALWAYS keeping the same polarities (North's are always North & South's are always South)
The rotary switch of Figuera was only pulsing the High-Positive end (only one brush) while all coils other terminal(s) were connected at all times Negative from Source.
Here I see same deal, except using FET's and a micro-controller...a bit more "sophisticated" but the same, exact final result.
So, resuming, here Induction works based on a Field Expansion (when Coils are peak energized) and a Contraction (when it is collapsing or tending to)
I have done Figuera in many configs, and it does generate induction this way.
Maybe this way of having all coils mounted on a single steel core for each (Induced and Inductor) will have more success.
Cheers
Ufopolitics
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
Continuing from my previous post:
In addition, if LinGen have a sequence by turning ON N1- S1 then OFF, then turning ON N2-S2/OFF, then ON N3-S3/ OFF, and finally N4-S4, and REPEAT...then it would be generating a displacement of Inducing Field from N1-S1 to N4-S4.
And IMHO, it should work beautifully. Basically, if I understand correctly, LinGen is designed to power small appliances, like a Cell phone, etc,etc.
Ufopolitics
―Leonardo da Vinci
rakarskiy
Why did you decide that Figuera does not change the polarity, or rather the direction of the flow? In my research, I just came to this particular system.
The problem is to follow the linearity of the change in magnetic induction, especially in a static design. The second problem is that this linearity should be with the load.
I also consider a pulsating change in the magnetic field from "0" to a maximum and back. Again, this is all, still needs to be connected to the phase and load circuit.
SolarLab
Quote from: bistander on January 18, 2023, 09:27:59 AM
Hi SL,
Do you realize that the steel would be working on minor loops regarding the B H characteristics?
Are you still using the grade which you specified earlier?
bi
Your comment:
"If in fact each pole does not swing polarity (N to S to N to S ...) then there are implications seen on the B H curve."
Your answer:"Do you realize that the steel would be working on minor loops regarding the B H characteristics?"
Thanks for your help - a great explanation ( ??? ) and - a super work-around/solution ( ??? )
BTW, the CAE provides a very good picture of whats happening (each nSec) both inside the device material and in
the air around the device - no minor loops (what ever they are) were spotted.
See the gif annimations posted earlier.
Also attached 3 Time Step Magnetic Field Intensity plots. Rotor is clipped - only Stator & LAP are shown.
Plus, LAP [Induced Coil 9] output & all 8 coils. Stepped looking Blue Trace (Coil9 - LAP) is due to low sample/analysis
rate in CAE.
Included the ending sample cartoon as well.
SL
