Magnetic flux motor just patented that creates it's own electricity!
Started by am1ll3r, March 02, 2023, 07:32:40 PM
sm0ky2
Well guys they appear to be right.
<1/4 ft lb = > 5 ft lbs
https://youtu.be/woejdNvCZpc
Need some quantitative testing with accurate measurements
But at face value it seems to check out
sm0ky2
Out of curiosity i tried to belt a motor to the upper disk
Hoping to generate measurable current
To my surprise; the spinning magnetic field tries to drive the small dc motor
(opposed at first but when i flipped it over tried to drive the disk that was powering it!)
Not sure where to go with that. To remove the situation i suppose i could find a longer belt
Jimboot
Quote from: sm0ky2 on March 24, 2023, 06:26:16 PM
could the prime mover be a pulse motor and do away with the belt?
sm0ky2
I don't see why not
So long as the pulse motor produces enough impulse torque to overcome the magnetic compression necessary to overcome the moment of inertia of the secondary rotor mass.
Also theres a number that seems consistent regardless of the size or proportionality of the device
I don't know what it means but:
Pi * r^2 = 1/2 pi having to do with torque amplification
(note: these tests were done with a diametric constraint of the gap size:[/size]
Total Gap (left + right) ~= diameter of inner drive magnet assembly)[/size]
i left just enough clearance for rotation.[/size]
[/size]
sm0ky2
Its slightly above 10:1 torque amplification
Adding more weight doesn't increase or decrease this value
Although adding more devices on a common shaft like the inventor might
