Sm0ky2's modified Voss Machine
Started by sm0ky2, January 23, 2017, 03:08:32 PM
sm0ky2
UPDATE::::  (Testatika Disclosure)
i have attached an image of one of the simplest, and smallest Testatika devices that was observed in operation by a 3rd party.
(it is unclear if or if not the device had been modified prior to this photo being taken, i will explain below)
on the image are numbers, defined as:
1: Negative Internal Capacitor (charge source)
2) Positive Internal Capacitor (charge source)
3: Neutral Bar
4: Positive Pick Up Terminal
5: Positive External Capacitor
6: Negative Pick up Terminal
7: Negative External Capacitor
8: Negative Depository Brush (Primary)
9: Neutralizing Brush
10: Parallel Negative Depository Brush (secondary)
11: Parallel Positive Depository Brush (secondary)
12: Neutral Bar
13: Positive Depository Brush (Primary)
First i will state, that after 2.5 hours of trying to get the device to turn on, nothing but failure.
After analyzation and some thought....
i made the following changes, and the machine light right up (yes i have a working device, as for what it does / can do, no clue yet....)
changes:
Terminals 10 & 11 were disconnected
terminals 8 & 6 were swapped.
i will attempt to reintegrate the secondary depository brushes, as soon as i decipher their proper placement.
think Paul tried to screw us on this.
perhaps to mask the technology..... who knows. but the above fixes work, and the machine runs.
videos' soon
Enjoy
sm0ky2
Short video showing the machine
https://youtu.be/6eKA4C1VxQg
Still not sure where those other 2 wires go
System operates with or without the 2 upper neutral connections,
However, the 3rd neutral IS a critical component,
Due to the unorthodox brush placement
System losses skyrocket without this
It can be replaced by any capacitance (piece of metal, leyden jar)
I could probably fine tune it to increase the output.
But as it stands the voltage is comparatively low compared to other machines
(10-15KV)
The current may be higher (as indicated by brighter/louder sparks)
But i need to run some tests to verify that
Next step is probably the perforated layered condensers
sm0ky2
I've played with this component on other electric machines
And it seemed to do nothing
but in this configuration:
Hmmm?
https://youtube.com/shorts/w7JQs8Z9Nfc?feature=share
ramset
Smudge has a contribution to peruse when you have time
I hope it attaches ok
From a post here https://www.overunityresearch.com/index.php?topic=4370.50
I believe it may be possible to invite Smudge or to correspond (for input ?
Regardless
Thanks for all you do ...
With gratitude
Chet
Thanks Grandma
