TopRuslan
Started by r2fpl, March 21, 2023, 11:47:39 AM
worldcup
Quote from: worldcup on May 30, 2023, 10:55:18 AM
https://www.twirpx.com/file/941403/
Fundamentals of the structure of matter from the point of view of the authors, Bolotov B.V., Bolotova N.A., Bolotov M.B., Bolotov I.M., 2009
Cannot attach due to file size, uploaded on random host - https://file.io/8FTqMtvOqmeB
Old link is not working anymore, here is new - https://anonymfile.com/2qPx1/wcup.pdf
justawatt
Why does anyone come forward to share their knowledge get backlash.
All message i see is ,it's fake ,how he faked it ,free energy don't exist blah blah.
Let's keep a open mind .
It is upto bunk to share his technology or not ,he is here maybe to help us or give his taught or not,he might have spend years researching his invention,we should respect each others work
justawatt
Another Russian technology 12 kw
worldcup
@justawatt, good to see you back online after a whole year or so..  :D
What kept you busy! ;) done any success with your don smith device ?
QuoteAnother Russian technology 12 kw
You got HD image of schematic! any device video link or reference would be great.
anything more,ty..
EDIT:
some info i could gather, it belongs to guy named 'Alexander' , more info and video over here - https://energyscience.ru/topic423-546.html#p39565
pix
Quote from: worldcup on May 31, 2023, 02:51:31 AM
I briefly went through that book.
I would put it into "popular science" shelf.
I must say, it contains many controversial content. Theoretical divagations disconnected from real world.
Example: two windings on one core, side by side, same amount of winds, one wound opposite with thicker inductor.  Authors claim that indictance of such doublet will be zero ,but magnetic flux nonzero. They claim this setup for wonders of many phenomena described in that book, as they claim this setup can work regardless of frequency.
They state that inductance of the coil do not depends from wire diameter, if number of turns are the same.
Well, that's not true.
Thicker wire over the same magnetic core , at given amount of turns results- coil length longer, coil outside diameter bigger, distance between turns bigger, resistance of such coil is smaller and that will lead to stronger current flowing in that paralell branch of doublet coils. And this directly affects inductance. So , winding mirror coil with a thicker wire will give different inductance than the same coil with thinner wire. Overall inductance of such doublet will be not zero and magnetic flux not zero.
Please check on any good coil inductance calculator:
Multi-Layer Coil Inductance Calculator (electronbunker.ca)
Coil32 - Multilayer coil calculator
Multi layer air coil design and calculator (circuits.dk)
Authors are taking simplistic assumptions on very beginning, and they build a controversial theories on such shaky foundation.
Althrough there is a simple solution to this, how to minimise inductance of such paralell connected contrawound coils doublet.
PS.I forgot to add another factor that autors completely omitted , that in such coils arrangement inductances of the coils will add up, it is the mutual inductance between them that introduces a negative contribution and may lower  total inductance.
Cheers,
Pix
