IEC Earth Engine First Magnet motor installed in Las Vegas
Started by ramset, March 14, 2019, 11:35:40 AM
rakarskiy
Did you think that Dancik or Holcomb would be allowed into the market system with their OverUnity devices? They flirt with the system, and the system "has them as it wants". Investing in projects that the system has identified as malicious is a lottery game, even with a hundred percent guarantee of the device's performance.
4x fluorescent tube (or LED )lamps radiating artificial photons to PV-cells/modules !
Here the (comercial) f-lamp 38 lumens/Watt (LED up to 300 lumen/Watt) is obsolete cause not in ' lumen/Watt in 1 mtr distance'-condition,
here applied the invers /square law and invers/cube law effect !
38 lumen/Watt in 1 meter/metre distance
equates
? lumen/Watt in 10 centimetre/centimeter distance
equates
? lumen/Watt in 1 cm distance
square/cube law :  dynamic distance change magnitude effect
inverse square/inverse cube law : dynamic distance change plenitude effect
Ergo :
equates ? lumen/Watt in 2,5,10 meters !?
Formulas are defined as 4d process ,conditionized !
The next ? Long FL/LED in long transparent solar tube panels ,tube in tube, here as  flat panel material demonstrated
https://m.youtube.com/watch?v=qMhdpWMDp04
F.e. as array by apply from :
http://www.rexresearch.com/imris/imris.htm
100x+ fluorescent tube lamps in solar cell tubes
In farer future : fluoresent lamps with transparent solar ink film coating ,heat/light-electric dots
wmbr
OCWL
SolarLab
Quote from: skywatcher on July 19, 2023, 11:08:15 AM
That's really one of the most stupid things i have ever seen.  ::)
Here's one that is - by your standards - even more stupid:
Hybrid Electric Vehicle Motor Made with Neodymium Magnets
https://www.youtube.com/watch?v=nggbeC4iY1o
Note how the polymer is made (SMC)...
Rakarskiy - BTW, they're already in the process of marketing it! But it takes time...
[The best way to screw yourself is to introduce a device and not be able to deliver
in a reasonable time frame (week or two at worst)] Patience!
SolarLab
skywatcher,
Please enlighten us as to why this is "one of most stupid things you have ever seen?"
Your detailed Analytical or Numerical Analysis would be very helpful!
Please consider all things - such as light power details, ambient day light, savings
calculations, cost of bulk solar elements, and so forth - just curious as to what they
all are, from an engineering prospective.
Your opinions are always welcome but they need a bit more clarification. Otherwise they
are just unfounded opinions based upon unfounded ad-hock evaluation.
Thanks.
SL
