Proven, smartphone-sized overunity (open sourced:) Steven E. Jones 8x overunity
Started by patch6, August 16, 2023, 02:21:56 AM
Quote from: adrouk on August 20, 2023, 06:44:25 AM
If you can tell me how is possible to run an led of 3 volts 20 mA for 275 days continuous from just 3 AA rechargeable batteries (actually 6) wouldn't be a huge challenge to scale up to desired load, is it ? Just think that you might not need a power bank for your solar system to be designed with tens of expensive batteries to back up your power needs for 2-3 days.
fractional milliWatts x 1000 = fractional Watts x 1000 = fractional KiloWatts
1 000 000 x or 10⁶ upscaling !? Size ?
1 KW NanoBOXX size ?
https://techconnectworld.com/World2017/a.php?i=1125
' back up your power needs for 2-3 days.' ? ,  not ! ,they : (Joseph) Birmingham Technology claims ≥ 10 years ,3652,5 days +
Btw : lead battery alternative ,iron2rust2iron cycle
https://newatlas.com/energy/form-energy-iron-air-battery-bezos/
A base source for cascading systems !?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=2&ND=3&adjacent=true&locale=en_EP&FT=D&date=19931111&CC=DE&NR=4222678A1&KC=A1#
Approved and granted ,C1 and C2 !
Is here the ' electrical unit' not as same a this ' microorganism battery ' above to see ? ! :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=13&ND=3&adjacent=true&locale=en_EP&FT=D&date=19790215&CC=DE&NR=2733719A1&KC=A1#
About size and consume/generation :
https://m.youtube.com/watch?v=XAPcN3jRuEg  ~    9V x 0,01 A
The liquid stimulating ? Brownian motion enhancer !
https://nanobox.ie/
Or :
https://paxscientific.com/water-techThe PAX Water Mixer can circulate 10 million gallons with the same energy footprint as three 100-watt light bulbs
Btw: the poste ' rechargeable' as roto-verter ' rechargeable circuit' concept,anno 1940,but how do we CONVENTIONAL connect 2023   +  and - pole,and how Mr.Debuyst ?
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=0&ND=3&adjacent=true&locale=en_EP&FT=D&date=&CC=BE&NR=438189A&KC=A#
. I must also draw your attention to the way the accumulator is connected.
This is connected from the positive of the dynamos to the positive of the accumulator and from the to the motor and the same connection for the negative, as it is marked on the drawing, it is not a question of confusing, because if have but the positive from the dynamos to the negative of the accumulator, and the negative of the dynamos to the positive of the accumulator, the voltage would be doubled and the motor would be burned.
nightlife
I feel that there is too much radiant energy in that room that could be be harnessed to give the results found.  Scale it up to show that it creates more energy then what can be floating around in that room and then I may take another look at it. To me, it's just another type of jule thief.
Cloxxki
Quote from: nightlife on August 20, 2023, 03:17:43 PM
Fair comment. If there are milliwatts out of nowhere, at least make the effort to scale to a substantial degree, if anything to prove that there is a decent yield per kg of materials, which is probably the best mass production proxy for cost of course excluding rare earth materials.
Even a perfectly scalable tech can be true OU and still utterly useless, if the power density isn't there. Say, it takes a metric ton of coppers wound in very intricate ways from 10 miles of thin gauge wire, to put out 10W continuous. Where to haul that 1 ton to, to get 10W, for what purpose?
