FIGUERA'S AETHER MAGNETIC FIELDS LINEAR PUMP, REVIVED
Started by Ufopolitics, November 11, 2023, 12:56:47 PM
Ufopolitics
Hello to All,
I started working on Clemente Figuera project around 7-8 years ago...my videos show all the attempts made.
I recently gathered those related videos, (some were "private" because they were shared only between Members building it at Energetic Forum) and then created a Play List:
UFOPOLITICS FIGUERA GENERATOR PLAYLIST
I highly recommend NOT to waste your time watching them...As these are all failed tests.
It was just done to show all attempts done without any major success at all, as also a Time Stamp for the records.
I used Bucking Coils idea (N<>N) or S<>S...No luck.
I spent a lot of money ordering Toroid cores, tons of brand new spools of enameled wire for coils plus building the infamous "Part G"...it did not work either...
I spent time and money in high wattage resistors, according to measurements required...nothing...
I made a lot of Animated graphics to understand how this is "supposed" to  work...
For Jesus Christ sake!!, does it takes that much wasted time, efforts and money to realize either this setup will NOT WORK...OR that We were all wrong from the beginnings?
For all of you that are on the same page...do not feel bad...we learned a lot or a thousand times and attempts it does not work...after all, we are not alone...the Figuera Patents, including Buforn's dates back to more than 115 years ago...and absolutely NO ONE have been able to prove it does work as expected, as described on all their patents.
But here, after close to ten years ago, three days back...by reviewing my videos, basically the graphic animated ones...I finally understood where we went wrong...big time wrong.
It is a very slight "Structural Wrong Geometry Interpretation"
It was NOT a Translation error from Spanish to English...My Native Language is Spanish, and I have gone over and over on ALL original documents written in Spanish.
When Clemente Figuera originally put together his 1908 Patent and Drawing(s)...He refers to "resistance" as "Espiras de Resistencia" (Resistance Spirals) inside a box, He named "R"...and He refers to it as "drawn for ELEMENTARY/UNDERSTANDING purposes only"...which means "NOT EXACTLY" the way it goes FOR REAL on his CIRCUIT...
Unfortunately, this great website is going to be soon on "Read Only Mode" (according to Stefan last post on the sell of OU.com Thread), which means We will not be able to post or open new threads after is set to that mode...
In my new development, I still have some more time to finalize this new design, physically, but I already built a simpler prototype to find out it works as I expected, even though is still NOT PERFECT YET...the difference is GALORE, from all previous attempts...plus other patches I added in order to smooth this new method of operation.
I am now in the process of measuring wire length plus winding coils (they ALL must be EXACTLY same length and geo size for it to work as expected...most cores were done before, just had to lathe a new one and scavenge from old spools of wire I had from previous work...
I just need more time to be able to DISCLOSE ALL MATERIAL with complete animated videos on You Tube plus make all the CAD's Diagrams for easier understanding.
So, please Stefan, I know you are feeling very ill, and am very sorry for that, as I am also very sorry you have not been able to find a buyer...but please, give me sometime to finish this work and post it here. Can you name someone of confidence, to just run this website as Admin, until it sells?
IMHO, by setting it in Read Mode only, will not help for the selling, as it will not allow interactions from prospect buyers.
I can still go to my You Tube Channel and upload all videos related to it, plus open a new Patreon link...for all those that want to REPLICATE IT, but a monthly fee would be applied if they want to watch my "how to" videos...
I can also post it on Energetic Forum, but their website has some running issues...
I can also build a website platform myself, I have the SERVERS...just related to this development, I can write codes, I know PHP, C++, MySQL and then some...and can handle most Forum Platforms out there, like BB, SMF, Bulletin Boards, etc,etc...but here is somehow "special"...
Actually, I was not supposed to post NONE of the above, nor future posts below, until I was ready for the whole package done and tested over and over to make sure there were no errors...But your recent post on "Read Mode" rushed me to open it now.
Regards to All
Ufopolitics
POST DATA: REMEMBER THIS IS A MODERATED THREAD, SO, ANY UNWANTED OR UNRELATED B.S POSTS WOULD BE DELETED/REMOVED FASTER THAN A RABBIT GETS FU(&ED!!!
Principles for the Development of a Complete Mind:Study the science of art. Study the art of science.
Develop your senses- especially learn how to see. Realize that everything connects to everything else.
―Leonardo da Vinci
Ufopolitics
By the way...
Do not keep on trying FIGUERA SETUP in a ROTARY FASHION of Virtual Fields...it will never work!!...I will tell you why:
On all the Rotary System I tested, there was a main issue, when I accelerated the Controller, the Output started to decrease, instead of gaining value.
Now in a straight line steel core, Fields are generated acting like a Piston Pump, one at each end. Let's call it like Figuera did, Part N and Part S, as the main Primaries.
They actuate in a Reciprocal way, so when one is fully displaced or expanded, the other one is retracted to its minimal capacity, and so on and on. They both travel within the same linear mass steel core, so Field never needs to "jump" from one mass of steel to another (even within same steel stator core) like in a Rotary System.
I know this all sounds "too familiar" and some of you may have tried these "scenarios" many times as well...but there is "a way"...only one way, of making it work superb!!
I have come to the conclusion, that making the Magnetic Field Spectrum jump or "mutate" into a "cold" (not magnetically oriented mass) like I have done in Rotary Systems in the past, it does not work -as well- basically, whenever we accelerate (increase frequency) trying to get higher gain at output. Field Spectrum can travel at speeds higher than light, however, the steel mass takes its "sweet time" to develop a magnetic domain orientation...So the proper "Sync" is lost the minute we accelerate field beyond mass response.
This will never happen in a straight line of steel mass core, where both fields are traveling -in a linear fashion- at different space/timing, the steel mass would always be oriented in one linear sense, no matter if we just change linear directions.
Ufopolitics
EDIT 1: And do not worry, this "Method" is not complicated at all!!...it is so simple you would not believe why we did not try it before!!
―Leonardo da Vinci
Ufopolitics
FIGUERA'S 1908 PATENT...LEGAL DISCLAIMER
At the time Figuera wrote his Patent, there were no "Claims" that required to be cited at the end of any contemporaneous patent does...However, Figuera aligned his designed patent into a "Block Diagram" type system, referring to "all parts" as "Elementary" cited: which "not necessarily" go exactly the way they should be on the real prototype.
If We follow this pattern of parts, we will have:
You cannot view this attachment.
1-Part "N" and Part "S" as the Primaries.
2-Part "y" as the Induced.
And up to here is very common as any Generator "now and then" had these parts on...
So, the "Novel Parts" to any existing Generator on Figuera are:
3- Part "R" defined inside a "Box" which he describes as "Espiras de Resistencia" (Resistance Spirals)
4- Part "G" as He describes "the controller", ran by a small motor and just one brush, which does not requires effort to operate, as all it does is like a "Rotary Mechanical Switch".
So, this are the Four Basic Parts for Figuera Generator...not more no less.
Nowdays, with all these four parts, we could put together a -very simple- Block Diagram, for a new concept Patent, which will make it for ALL CLAIMS required by now.
As Figuera recites on his final paragraph on this patent, that "any similar system that uses similar methods will fall into this main design and would be protected by its patent laws.
Which means that we now can move or re-arrange all these "boxes" off a Block Diagram...and still be using his method, no matter if we use as Part G, as a "Fancy" Solid State Electronic method for switching...it is still within the scope of original patent...which by now, is completely Public Domain, and out of any "Legal Liabilities".
However, since this patent(s) have been on Public Domain for close to a Century...this makes it "Not Patentable Status" if anyone will try to "run" to USPTO, trying to file an App, with a similar device, which will have the LEGAL ESSENCE of this Patent.
Ufopolitics
[attachment deleted by admin]
―Leonardo da Vinci
Ufopolitics
Finally, so I can get back to work...
In the event this website goes "South" or into "Read Only Mode"...You can always subscribe to my You Tube Channel and it will automatically notify you when I upload a New Video...plus comment there...
On my profile is also my email acct, in case you want to communicate with me....and please, do NOT just send me mail to "chat"...I really do not have time for gossip...sorry!!
Regards to All
Ufopolitics
―Leonardo da Vinci
citfta
Hi Ufo,
If I can do anything to help either publicly or privately just let me know.  You know how to get in touch with me I think.
Take care,
Carroll
