First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
skywatcher
Quote from: Tigrotto on December 16, 2007, 02:14:18 PM
The problem is this:
I understood your errors from a physical point of view. The others our friends, most of them, don't understand this!!!
Where do you see errors in my posting ?
What you are saying about power, and measuring it with a resistor, is absolutely correct.
What i said: even when there is a voltage, but no power to measure in the sand, it would be interesting, if this voltage only occurs after putting the sand into the pyramid for several hours. Of course you can measure voltages everywhere with a high-impedance voltmeter, but if you can measure a voltage after 'pyramid treatment' which is significantly higher than the voltage without this treatment, then i would also consider this as remarkable.
neptune
I spend a lot of time looking again and again at what has been previously posted on this subject. I just noticed something which validates something I said previosly. Look at the picture of the converter on page 1 of this subject. OK , we know this is not the V6 [or v12] but look at the coil wound on the bottom bit of the copper frame. Notice;
1 It has a larger internal diameter than the external diameter of the copper tube[it is a loose fit]
2 It is not co-axial with the copper tube.[ It is mounted off center]
  In the plans for v6 TT says wind coils with wire of2.5mm diameter and an internal diameter of 25mm [of the coil]
           This more or less shows what I said . Do not wind coils directly onto the copper. Thre must be a space, or perhaps cardboard in between.
Tigrotto
@skywatcher
That's correct now! Maybe it was only my misunderstanding asI'm not an English speaker!
Apologizes,
Tigrotto
Tigrotto
@neptune,
Agreed ( insulated wire!),
otherwise ( if no insulated wire wounded on copper frame) means not use for wounding coils !
Tigrotto
skywatcher
Quote from: Tigrotto on December 16, 2007, 03:14:58 PM
Apologizes,
Tigrotto
Ok. That's a problem for most of us who are not native speakers of English. But your English is much better than my Italian.  ;)
Today i finished building my pyramid frame. Infos about it will follow in the other thread.
