Faster, cheaper, lighter, smaller, and more powerful with NO volt switching!
Started by kmarinas86, December 18, 2007, 07:21:17 AM
kmarinas86
Favored (because these qualities allow the machine do quick and nimble things for a longer time)
mechanical power
angular acceleration
torque/volume
torque/mass
torque
longevity
Neutral
resistance
voltage
loops, wire
length, wire
charge capacity
area per loop
diameter, wire
Disfavored (because these qualities prevent the machine from do quick and nimble things for a long duration)
current
mass
volume
The chart below consists of the solutions by a Microsoft Excel add-in.  What the chart below shows is that in order to follow the criteria above, you have to increase certain parameters at a faster rate than others, while decreasing others in the process.  The rate is r, where x=(1+r).
x^9: resistance
x^8: voltage
x^7: mechanical power
x^6: angular acceleration
x^4: torque/volume; wire loops; torque/mass
x^3: wire length
x^1: torque, longevity
x^0: charge capacity
x^-1: current
x^-2: area per loop
x^-3: wire diameter; mass; volume
Consider x=2.  We would have:
512 times the resistance
256 times the voltage
128 times the mechanical power
64 times the angular acceleration
16 times the torque/volume; wire loops; torque/mass
8 times the wire length
2 times the torque, longevity
The same charge capacity
50% of the current
25% of the area per loop
12.5% of the wire diameter; mass; volume
The above suggests that while the possible mechanical power is limited by electrical power, its possible have negative relationship between power and volume, power and mass, power per current - SIMULTANEOUSLY.  It's only a matter of engineering as to how small, and powerful, and how long lasting the motor can be.
Ray0energy
Quote from: kmarinas86 on December 18, 2007, 07:21:17 AM
mechanical power
torque/volume
torque/mass
torque
longevity
Neutral
resistance
voltage
loops, wire
length, wire
charge capacity
area per loop
diameter, wire
current
mass
volume
x^9: resistance
x^8: voltage
x^3: wire length
x^-1: current
x^-2: area per loop
50% of the current
still a lot of BLA BLA he ;) ???
or in Holland we say (praatjes vullen geen gaatjes) or Talks fills no holes :P
place build something and then u talk
