Mehess Motor
Started by billmehess, April 07, 2006, 01:33:35 AM
@maxwellsdemon
He said, he can produce more energy with it than it needs to rewind the clock,
so it runs perpetually and can deliver excess energy to a connected small load.
maxwellsdemon
Quote from: hartiberlin on April 08, 2006, 02:36:27 PM
@maxwellsdemon
"Can" produce more energy, or does produce more energy?
allcanadian
So it's a clock with a pendulum and a pm rotor on the pendulum-interesting . Pendulums are very conservative,and I cannot see what role gravity would play here so Im guessing it's a timing function.Too many people rush things, current being one of them, If you allow the pm enough time to work with electron/current flow and not against it maybe we can come out ahead. I have thrown this adea around forever, using a magnet on the back of a coil and a larger metal plate as a rotor so all current flow has ceased by the time the rotor leaves. As well, I think almost any mechanism is better than the current generator systems we use today, they are terrible.It may not be big power but it is power none the less, I wish you the best of luck. I found an excellent web page on the wesley gary motor you should look at, Im in the process of building his motor and kicking around the idea of putting a resonating arm on the opposite end or a pendulum, one input-4 outputs? Veljko Milkovic's pendulum is interesting as well. Here is the link for the gary motor(http://www.fevj.org/FEV-magnet-motor-by-W-W-Gary.php) it is the best I have seen yet.
billmehess
Its Sunday night 9:15 Pm PST, I just got home and ready the replies on the site.
So here goes:
I believe that the answer to a working magnetic motor is the ability to utilize a power source to run the motor. I do not believe that a magnetic motor will run by itself. This is like trying to grab your shoes and lift yourself off the ground. Does it not strike all of us as strange that NO ONE has been able to build such a motor. I do not believe the Snyder or Argentine motor will work. I saw the Synder video like everyone else how hard is it to attach the motor to a stationary platform and see it work on its own?
Butch, I know you are shaking your head now, and I have the utmost respect for you as does I am sure
everyone else in the community but until I see a working Synder or any other motor I simply cannot
except it as a working device. If I am proven to be wrong -so be it, its ok but I am a real nuts and bolts person I simply want to see a real working device.
Enough of that
What I have in my motor is a way to create a electric current by passing a permanent magnet in and out of a coil. This is certainly not new and I do not claim it to be, Faraday is well understood.
The problem is how to keep this motor continuously running. For this I am using the back and forth motion caused by a pendulum from a mechanical movement of a clock.
Its so simple
With this process I can generate current for up to 31 days using a 31 day movement. I am currently using a 8 day movement. During that 31 days I will be storing the output via capacitors or work to directly trickle charge a rechargable battery.
Think of each permanent magnet moving in and out of a coil as one (1) power unit producing over a 31 day period x amount of energy. The more of these power units I have working the more output will result. Remember each unit is really totally independent of each other so "stringing" these together and connecting them in series will produce any voltage I need its only dependent on the number of units in use.
Its so simple
As far as re-energizing the movement to cause the device to continue to operate I need only to store enough power to turn a motor for under 10 seconds which will begin the 31 day cycle all over again.
Tomorrow I will begin building the next upgrade model will the n-45 2in in diamenter 1 inch long magnets I have which will be moving in and out of larger coils. The 2 magnets I am using now, and that show in the video are only 3/8' wide by 1/2". The greater amount of current that will be produced with the stronger magnets will be dramatic.
I can produce enough flow to in 31 days rewind the movement as well a plenty left over to light a bulb.
Talk is cheap I HAVE NO DOUBT that I can do this, after reading this I hope that you can understand how this device works.
Its so simple-
Producing a current continously for up to 31 days= energy
This unit is not area or input specific. It could work anywhere, in a closest, a basement in a cave it makes no difference. It does not require water(Hydro) the sun , wind or any kind of peto fuel to run and it can run continously producing a flow of truely FREE ENERGY.
                                            ITS SO SIMPLY- SEE THE VISION!!!!
REMEMBER!!!!!!
I need only to string as many of the magnet/coil combinations together to achieve the necessary current flow.
This is very important- this unit it generating electricity and the power that is required to run it continously only has to be tapped once a month. All other magnet motors must be providing its own input  from second one. There in lays the problem for that kind of motor. It simply cannot produce more than what it takes to run it-basic law of physics folks.
