First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
MT
Quote from: Walter Hofmann on December 24, 2007, 05:46:28 AM
I only measure DC and just for control I switch short to AC but nothing on AC just DC. I did not connect the pyramide frame to the ground jet. I will use a seperate ground rod outside any building to avoid influence.
after TT's explanation the voltage should start rising within a feww minutes you dont have to wait hours if nothing happen in the first 10 minutes.
Thats clear, effect should be on DC I was just curious what is to see on AC scale. When the effect actually disappears in your case? Moving it 1 mm off center or 1cm? or you see it always and in center is much more. When you move converter a bit can you see changes immediately on DVm or it take time to build up? Hope I dont ask too much.
Maybe I should try sand from IKEA or other sand at the moment using quartz sand SiO2 from a glass factory. Also my stand where converter hangs is also not that convenient to set it is actually a stand for vine bottles.
I did not mention yet, few days ago I visited a nice guy who has 4x4m outside pyramid for few years. He is using it only for healing purposes. He never heard of using pyr for making electricity but was interested to hear about TT story. His pyr has wooden frame and is covered with aluminum sheets and of course has north orientation. Height I dont know but from context I understood it has ratio as Egyptian pyr. People that came to him got some help from diseases lying in it but also some got noting. He was surprised that I build frame from iron saying iron attracts energy to itself and such construction is never used for healing. He said there are two types of radiation one from ground and one from space. Earth radiation is bad and not desired! Healing comes from space, space radiation=good. He confirmed water not freezing in pyr and clearly changed vine taste(to softer). Also that water from pyr boils in 10min in comparing to normal water which does it in 20min. Then discussion went to esoterism. I got small alum pyr from him for sharpening razor blades. He is shaving daily with one blade for over 1 year. Blade became already a bit rusty but he said it is still good.
Merry Christmas to everybody,
MT
magpower
Quote from: pese on December 24, 2007, 05:34:33 AM
Quote from: duff on December 23, 2007, 11:16:12 PM
Quote from: magpower on December 23, 2007, 10:41:14 PM
Duff
Thats something we don't really know for sure air or solid dielectric for the caps. I did back off on the screw and have set to 940pf right now. I used paper to keep plates flat. I will adjust it slowly each day and watch for changes. The only thing that I haven't used is 2mm graphic rods, but using pencil, I thought I would see a volt or so. I think if everyone trys something a little different we might get it. As for ground using my house ground. One thing I did notice if I bring my hand close to center cap the meter jumps up to 150mv or more, but did not touch it, so seems its picking up something. On DC I get nothing?
Sorry but I believe TT specifies an air dielectric.
Perhaps our German friends confirm this from sketch 3:
jeweil 1mm Plotten LUFT
Google translates as: Jeweil 1mm plotting - distance air
jeweils 1mm Plattenabstand
in each case 1 mm of record distance  (plate to plate)
LUFT = Air between the plates.
not use dielectricums !
Pese
Thanks Pese
I will change this over in the next few days, any idea of what the value might be close to. And should the output be AC or DC ?
Magpow
pese
Quote from: magpower on December 24, 2007, 08:04:07 AM
Duff
Pese
Thanks Pese
Magpow
i think :
the cap is not an part of LC resonance circuit.
so the cap.value will not be important .
the cap is an part of "antenna" OR:
an cap to have DC as output  (if the Oszillator will cones as an "funcion" of coil , tubings grafit.
I think , NOTHING have to do with our understanding from Elektronics or physics.
It?s will be come from "aetherics sciense , so as Dr.Reich have found somes. Also as Joe was in
experience with his "Cells"  (Joe-Cell).
It shown all " excentriic , unbelivibel , but i think, we will lear , with an open mind.
- sorry my "low-knowledges " in english-
Pese
P.S.
OUTPUT will be , in any way DC.
As load you can use also an bulb (from flash (no LED!)
so you see .
if your DMM can and will not work with
AC from high frequency (to be shure in any way)
Possibly the Gypsum walls from 2,3 or 4 sides are necessary.
possibly the radiation will be focussing in the middel (to converter).
Remember that hubbard an Moray have also "forced" small power
to "high" power with very small "radiating" -NUC- sources.
This "sources" are not open - or even surpressed , because
free energy is not wanted , if you will "earn money"
neptune
@Tinu. sorry you feel that all your work has been in vain. Before you give up totally, Why nottry a couple of things. Have you done any tests outside? [not easy at this time of year. ] An idea that keeps coming to me, is to replace the graphite and sand with 2 small zinc carbon cells inside the copper to replace the galvanic cell My hope is to get more power out than in. The best set up would be one new cell and one partially discharged. the negative of each cell is connected to the copper and the positives to the coils. I cant try it myself until after Xmass.
                If we can confirm ANY strange effect happening inside the pyramid but not outside, then we may be onto something. All I will say about the subject you ask for comments on is this.
You will not necessarily learn much about free energy from this, but believe me, you will learn a lot about human nature.
magpower
 compared.jpg   I know this is a older version but looks like the 2 inside rods are connected together.  And on real picture you can see the copper tube, just maybe connecting to frame, which would make more sense. First will change my center cap to air dielectric and go from there. I hope Thomas comes back !!
Happy Holidays
Magpow
