Artic_Knight
the difference in hight for the probes didnt work for me but maybe i didnt do it right, i still think it should work.
yes bill you have the idea with the coils its ontop above ground and use the zink rod to test it, i think the zink will have an iron core, try your carbon too while your at it just put something between that bare wire and the probe, i shorted mine out and it didnt really work that well but still got voltage, just no current! wierd eh?
Artic_Knight
im sorry if that is what i have said, ive been getting .1mah sometimes .2mah on all of my experiments :) if i break that barrier you will here a lot more than a passive comment about it here, ill be making a fit of it :-p
what i feel is important with this coil set up is it is mostly ac based!Ã,  dc doesnt do that well with this set up
also worth noting this wire around the rod in the ground, i tried this approach with the aluminium and it worked but was not as satisfying, i believe the iron (and steel) has something that helps
bill somthing to look at, i thought my wire was bare, its enameled, it has a clear plastic coat :D
Bruce_TPU
Hi Bill,
My setup worked on increasing the voltage, but still no amperage.  My 1/2" carbon and magnesium will be here this week and I will be hoping for some ma readings.
I would suggest you try putting your carbon and magnesium as close to one another as possible, without touching.  Perhaps put a plastic knife, or something between them.  Make two of these couples, spaced about 15 feet apart (To make sure they don't short each other out) and wire them in series as I showed in my drawing.  Your voltage should now be doubled!!
All of those old patents were always carbon and zinc and one mentioned "excellent" magnesium.   ;)  Also, I am feeling confident that this is telluric current, because the south is always negative and the north positive, as it should be if it is telluric current being tapped.  So that too is a positive thing.
I would suggest the following:  Try two couples in series.  If it works at fifteen feet, continue moving one couple closer to the other, and see how short of a distance you can get, before series no longer works.
Then, once we determine that, we can wire in series to reach 12 volts and then start another row in parallel to give us much more current.  Then we test and see how long the magnesium and carbon last, and power some real lights!!   ;D
Let me know what you think.
Cheers,
Bruce
Pirate88179
Artic Knight:
Thanks for the answers. How are you measuring ac amps? I have both a digital and analog meter and I don't see any settings or scales for ac amps.  I can pretty much get 2.0 mA (DC) on a consistant basis but I hope to do better once I finish winding this new device.  I have already wound 25 feet of wire on it and am a little less than halfway done!! If this doesn't do any good at least I'll have a very, very long copper slinky.  This is bare, no coatings which may turn out to be a bad thing. I will see. Thanks.
Bill
Pirate88179
@ Bruce:
I agree about the telluric currents.  My neg. is always to the south also.  If just pure galvanic, it would not matter where it was facing right? I keep trying to explain this to several friends who think I am nuts. I am going to try this new device which if it does not give me a decent improvement I will go back to the "standard" set-up and use your arrangement. About 6 feet apart (n/s) is as far as I can go in my little garden here. This is all the room I have to work with at the moment.  but, I believe your idea will work even that close, and I will try it.  Wonderful thinking there.
Bill
