Steven Mark`s TPU
Started by otto, December 18, 2007, 01:55:48 AM
weri812
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
weri812
Hello All
@AhuraMazd
I will clear up my dumb question.
What size is OTTO's new tpu 6 inch across , 8 inch across ,  17 inch across  ? ? ? ?
Makes a diffrence when ording wire, and how many turns.
wer
nickc44
@ Otto
I did see the thread with your 3 rings but  I didn't see the thread with the circuit attached to F1 F2 F3
So I did not now if you were using tubes to give you those inputs Thanks for clearing that up
Part 2 of this question is I do not have the circuit before the rings so @ all if any one has this could you please
post it Thanks
Also you say on each ring you rap with 57 turns and then and this is the question... you stack each and then add
I think you said 250 turns around all ??
this may help or at least it did in the case of the bedini coil when I had 250 turns with  2 cables wound together
(one was used to trigger the transistor the other to send power to the coil and push the magnet on the wheel to the next position)  with  a core of welding rods I needed a wheel with magnets passing the coil to turn the circut on
My point: when I increased the turns on the coil to 1000 and used 4 cables of the same length one as a trigger and 3 tied together ( to power the coil )  I could trigger this coil once with a magnet and it would run on its own from that point on.
It was generating enough electricity to trigger the circut
( By the way when this happend for the first time I thought it was going to F(*&(& King explode )
this was using .20 wire
I was using 36v
As I have said before by adding more turns it seemed to resinate I think like you would like
Again this is just an observation in a like kind product that may help
I thanks the other gentlemen for pointing me to the other threads
Nick
Gustav22
@weri812
Quote from: weri812 on January 08, 2008, 03:25:18 PM
wer
Quote from: otto on January 07, 2008, 05:57:57 AM
Hello AM,
as Im following our master the dimensions are well known: outer diameter of the TPU is 6", inner diameter 4", height 1 3/4". I hope I didnt wright the last measure wrong.
The core is made of cork. .......
money for rope
weri812
