First electrical power output from a Pyramid
Started by hartiberlin, January 18, 2006, 05:32:45 PM
0 Members and 31 Guests are viewing this topic.
neptune
@ The Eskimo Quinn. Thanks for that information. It is not true that all batteries have to be charged before use, There are 2 types of batteries, or cells Primary cells do not need to be charged before use,e.g. zinc-carbon cells as in cheap torch batteries. Secondary cells such as lead- acid cells have to be charged. The clay jar batteries you refer to have been replicated, and are primary cells. There is evidence that they were used for electro-plating, and I believe that ancient electroplated artifacts have been found.
The Eskimo Quinn
quite right, i was only noting how the effect was discove rd and that the batteries in question contained copper sheet eluding to the fact they are more likely a capacitor type battery needing a charge, as opposed to the other type which would make them disposable and many more would likely have been found.
I like the electroplating theory though, never thought of that, i was going with atrophy, an ancient electric muscle stimulator, perhaps even an after death muscle mover for priests or Pharaohs to show life after death, to show god like abilities.
My PROOF THAT DEMOCRACY IS DEAD AND THAT WE MUST ATTACK AND KILL THE NAZIS IS RIGHT IN FRONT OF YOU, THE U.S, aUSTRALIAN AND BRITSIH GOVERNMENTS ARE THE OPPOSITION PARTIES TO THE ORIGINAL INVADING GOVERNMENTS, DEMOCRACY DIDN'T WORK, BOTH MAINSTREAM PARTIES ARE NAZIS, DEATH TO THE NAZIS, DEATH TO ALL SYMPATHIZERS AND SUPPORTERS http://www.youtube.com/watch?v=39c-kpgDY58&feature=related
duff
I have been testing but have failed to produce any results.
Attempts have been made with the pyramid on a concrete floor (rebar embeded), on a plastic work bench with 3/4" plywood on top and 33" above the concrete floor. I also tried replacing the plywood with a gypsum base.
I have not yet tried outside on the ground.
Then today I thought I would remeasure the frame and found it 3mm out of square. Before I welded it was right on, so I guess welding pulled it out. Thomas warned about this but I failed to catch it at the time.
I don't think there is any point in me continuing testing with this frame however I will give it one final attempt outside on the ground before giving up on it.
I'll probably start building another fame in a few days. It's not expensive - just time consuming...
Would you guys check your frames and let everyone know the results. Hopefully you did better than I did...
-Duff
Walter Hofmann
Hi neptune,
just look closely at the top and edges where the black wires are comming outbthere is nowhere a tiny bit of solder to see and from experience to solder any kind of wire to this copper blade needs quite a amount of heat what would melt the plastic of the wire what is nowhere there to see. seeing the other solder places where you clearly can see it is soldered brougth me up to this idea and also the the one turn of the wire coming from the right graphite rod, also the fact that there is no other connection of this black wire what could make it a capacitor.
greetings
walt
Quote from: neptune on January 08, 2008, 03:00:55 PM
Hi Walt, and thanks for your input.However I am inclined to agree with Duffs post on the Yahoo site when ha says that the black wires visible at the upper corners of the central cap, are just to connect individual positive and individual negative plates. You idea of a coil interleaved with the plates is feasible. As always it is best for us all to try different ideas.Re the V4. Assuming the central cap plates are sized as in V6 [ and there may be only a total of 6 plates in the v4 cap] then the copper frame is considerably taller. we do not know the length of the graphite rods in v4, and there appears to be no saltwater drain holes. I am experimenting with a test tube full of sand, to try to create a formula to determine what quantity of saltwater will wet a given volume of sand. Thus I can put the saltwater in before the sand.
            Is anybody satisfied,or not, that they can demonstate any effect , however small, that happens inside the pyramid, but not outside.
           Also does anybody who has a theory about the origin  of "pyramid" energy" have a theory about the shape or direction  of the field, rays, etc inside the pyramid. The more we find out, the less we realise we know...
neptune
@ Walt. Thanks for info You could well have point about the soldering, this also matches my experience, I will give it further study tonight..As i said yesterday, we have to try both approaches.
               What we do not know, is how TT came up with this design initially. There was some simple basic discovery/ experi,ment which then lead to further devellopment. We are trying to start at chapter 10..... I keep trying random tests with just a coil or a cap and a voltmeter , but nothing yet.
@Duff, please dont rebuild your frame, just cut a bit out or put abit in and reweld. As TT said, no prize for the prettiest pyramid. Right, gotta work, see you later.
