Giantkiller moves forward into Full Heterodyning.
Started by giantkiller, September 22, 2007, 12:39:11 PM
0 Members and 20 Guests are viewing this topic.
acerzw
@GK
I can see why some are worried about the dangers, scalar waves can and have been used as weapons, this post is not intended as negative, just to show that they are already in wide scale use as Tom Bearden has said, it is not just paranoia, details have been surfacing for some time:
It is rumoured that one was used in Iraq mounted on a modified tank:
http://www.2012.com.au/Super_weapon_Bagdad.html
The russians already apepar to have/had several working models on a large scale, look at the photos here... Wydenclyffe anyone?
http://www.abovetopsecret.com/forum/thread319602/pg1
My personal favourite is here, I have attached the main picture to this post, which I think was posted before by someone:
http://freesrpska.org/en/index.php?Itemid=30&id=58&option=com_content&task=view
So scalar wave interferometry is clearly the way to go. It is said that crop circles are created by scalar wave interferometers in continous mode. People who have seen crop circles being created say that a small fireball like ball lightning creates them, which is basically a description of a plasma ball that is created when two scalar waves of the correct frequencies and power interfere with each other. By timing the waves correctly it is possible to move the ball around in 3 space. It is not beyond belief that this was done by someone to either make people think aliens were here, wake the public up, or as a subtle warning to other countries where the circles appeared that the someone had the technology. On the other hand the operators of the machines could have just been bored!
On a positive note while GK's setup is fantastic, for others it might be worth constructing a simple adjustable high frequency scalar wave interferometer to experiment with very carefully... perhaps like Hutchison or perhaps two devices pointing at a single point, but they should always be activated remotely from a safe distance for safety purposes as GK is doing in an area with no people around... the first article linked to the above shows the dangers, so only do it if you have the necessary skill... it is very very dangerous...
A
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
Shanjaq
@Acerzw:  That first link to the tank-mounted superweapon sounds a lot like the Laser-Induced Plasma Channel.  A femtosecond-pulsed UV laser breaks down the air dielectric, allowing high-voltage AC to pass with little resistance to the illuminated target, confining the arc to a lossless channel of atmospheric plasma.  It figures they would take this to the extreme...
Imagine using that as a zero-friction commutator?
acerzw
@shanjaq
That is possible, however some accounts refer to the fact that the remains of the humans in the bus appeared to shrunk down to the size of babies... the account I linked to was not the original one I saw, which unfortunately I was not able to find. Though the laser induced plasma channel is also an interesting and horrific device...
A
sparks
   I contend that there are two fundamental forces at play in the physical Universe.  One to make all as one and the other to make all void.  The construct of matter totally reliant on the play of these two wills. Energy is but a change in being, goverened by these two wills.  Scalar waves can be thought of as propogating in a media.  Kinetic energy being converted into a compression wave at the scource of the converter that then travels through this media and takes the form of compression then relaxation of the media.  This is not em waves as we know them.  Somewhere back in the 50's there was alot of work done on producing scalar (sound wave type) em waves.  Telsa's dream was to produce these scalar waves in such a way as to benefit man by wireless power transmission: but along comes somebody and takes his work and develops a weapon.  Alot of scientists refer to dispersion force as vacuum energy.  It is a force not a form of matter/energy.  So someone figures out a way to create a vacuum here on Earth.  The vacuum is void of matter so the dispersion will does it's thing and fills it with void force.  This can be thought of as a magnetic liquid with all lines of force flowing in such a way that it becomes a quiesent construct.  Hard to invision something flowing and yet not moving.  Now into this column of "vacuum energy" is introduced some matter.  And the dispersion force does the rest. It disperses this matter (matter arising from equilibrium state of the two fundamental wills) with a vengance. So now man has the ability to generate energy (energy is change in being) by a new means that is not reliant on em mainipulation that results in kinetic energy being converted to potential energy in a conductor.  First thing he does is make a weapon.  What is wrong with us?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Center pulse trigger coil mounted with wire terms.
Adding termination blocks on first ring coil. Designing nonmagnetic brackets to suspend all coils in place in tube.
Any misuse is use for or against something that refuses to change whether right or wrong.Terminology is always a misnomer.
--giantkiller.  8)
