F.B.D.I.S.S.M - Flux.Boosted.Dual.Induction.Split.Spiral.Motor.
Started by Honk, October 11, 2007, 02:30:42 PM
Honk
Yesterday I sent the Mumetal pieces forming the new high perm solenoid core for heat threating in a hydrogen owen.
I asked for maximum permeability and hopefully they'll reach 250000 if possible. When the pieces return I can finally test
the difference between ordinary Oriented Steel at ?=15000 versus Mumetal at ?=250000 to see the flux difference.
My new gaussmeter have probably arrived by then and I can test the face flux and also test the force gain in the wodden rig.
I've read that most flux is returned inside the Solenoid through the core itself because this is a lot better conductor than air.
This is why Solenoids have small levels of face flux on the outside of the core. It's simply because the core is not getting
saturated due to the very large airgap of a Solenoid. But using a high permeability core that saturates at a lower level (0.8T) will
allow for higher ouside face flux. When the core is getting more saturated, less flux can return inside the core material itself.
There's some other very interesting Magnetic Alloy materials that have great permeabilites at ?=1000000 and saturates at 0.57T.
Later on, if successful, I might have a core made to fit the motor. Perhaps it will increase the performance of the motor.
http://www.metglas.com/products/page5_1_2_6.htm
Magnet Power equals Clean Power
Schpankme
Quote from: Honk on January 25, 2008, 02:58:16 AM
My new gauss meter have probably arrived by then and I can test the face flux and also test the force gain in the wodden rig.
Hey Honk,
When you ordered your gauss-meter, were you looking for a specific brand or specific features ?
- Schpankme
Honk
Yes, I wanted a gaussmeter capable of measuring both AC and DC fields up to at least 2 tesla.
And I wanted an attractive price to. Many gaussmeters at eBay is overpriced.
The one I bought at $240 handles AC and DC fields up to more than 3 teslas at very good precision.
Honk
The magnets have been ordered and Iv'e been promised delivery on the 28 of february.
Meanwhile I'll continue my cad drawings and solenoid testing.
Soon I can start building the Split Spiral Magnetic Wankel Motor and not long after that
we will know if there is any OU to collect.... 8)
Btw, I made a decision to build a lot bigger motor than the small 20cm rotor.
I believe that size matters in the potentiell OU capacity of this design.
The new motor is using a 60cm diameter rotor and a lot bigger magnets.
Expensive as hell, but I hope it will pay off in the end.
supersam
@honk,
i think you maybe thinking in the wrong direction!  asimov, once depicted a world that was getting smarter by getting smaller, with more more power.  i think this is the wave of the future. smaller but still with the same power!  not that you are wrong, but i think, that you can benefit from looking at the concept even from a micro, standpoint.  there are alot less energy requirements from systems on this level.  and also alot less things to go wrong. just my thoughts, and some others!  think about it for a minute.  what if atomic powered devices fit on your wrist?  where is the major radiation problem?  how much radiation could be released from a device that was meant to run a wrist watch?  not much.  you see the point.  how much plutonium to run a car?  i guess not much really.  the problem is in consolidating enough to run los Angeles then you have enough to blow up alot of people..
the problem is getting people out of the mindset that this might be acceptable.  sorry i am not convinced that certain governments are of the same mindset.  so let's just hold onto the knowledge.  even though we have now discovered something even better, that doesn't have the same potential for damage to the environment strategically, however it has the ability to provide any one person with all the power needed to explode the planet.
do we release this knowledge?  hmmmm!
lol
sam
