Energy From The Vacuum - Bedini Documentary
Started by kweising, January 27, 2008, 09:02:04 PM
kweising
Hello All
I have just seen an excellent documentary featuring John Bedini. John demonstrates most of his machines and explains, in great detail, how they operate. Very informative. Go to Tom Beardon's website @ www.cheniere.org for more info.
Schpankme
Quote from: kweising on January 27, 2008, 09:02:04 PM
Hello All
kweising,
How did you know about the DVD - Energy From The Vacuum ?
What part of the video do you like the best; my favorite parts are @ 0:53 - 0:58 & 1:06 - 1:15 ?
What did you think about Mr Bedini pulling out a dead battery every-time he wished to prove the SYSTEM charged ?
What did you learn about Capacitance ?
What did you learn about Impedance ?
Which Model of the Bedini motor will you be making ?
How often did the circuit Pulse the Coil per Second ?
Mr Bedini wrote a book in the 80's, which promoted a specific Design, why doesn't he use said design ?
My Energy From The Vacuum DVD took 8-Business days to receive; how was your shipping time ?
- Schpankme
kweising
Hello Schpankme,
My, so many questions.
I have been interested in Bedini's and Beardon's work for some time, so it not difficult to find the DVD's, all of which are informative. There is no particular part of the DVD I like best - I like all of it. His constant use of dead batteries simply demonstrates the efficacy of his system - charging batteries without current is certainly unorthodox, but he is an unorthodox man, don't you agree?
At present I have no intention of building Bedini PWM designed motors - my interest has been gravitating towards magnet motor designs - no batteries required. One of my "hobbies" is collecting patent applications, and to date I have approx 1200 patents, all of which are magnet motors. I shall be posting many PDF files in the near future about these motors/generators.
Only John Bedini knows why he chooses to use the systems he uses, for me to suggest a reason would be pointless, and besides, the systems he uses WORK. You cannot deny that.
I live in Australia, and delivery times are approx 2 weeks.
Regards from Oz.
Schpankme
Quote from: kweising on January 27, 2008, 11:24:25 PMI live in Australia, and delivery times are approx 2 weeks.
Hey kweising,
I was just screwing with the New Guy .. . :D
Glade to have you on OverUnity.com
- Schpankme
Koen1
Well... Bedini's motor/charger circuits do work... in most cases...
But one does come across quite many reports of the batteries going dead after
extensive use, and when one hooks those up to a normal grid-powered charger,
they tend to suck up several times the total power needed to charge a normal empty battery...
It has been suggested that Bedini basically "deep cycles" his batteries using the
positive pulse that occurs in his circuits.
That positive pulse, a form of emf, is referred to by Bearden as a "negative energy pulse".
Oddly enough and although Bearden spends almost half of his book "Energy from the Vacuum"
describing his negative energy interpretation of Bedinis trick, and even describes extensively
how such a negative energy spike is generated and can be used to "pull electrons from the active vacuum"
in a relatively simple capacitor setup, Bedini's motor/chargers do not appear to utilise that described
and relatively simple method, but rather Bedini uses induction coupling, a rotating motor, and always uses
the batteries to use the "negative energy spike" directly as input to the battery, which gets charged by this
"negative energy".
This seems a bit odd to me... If you could transduce that "negative energy spike" directly into normal electron
current, then why the heck would you not charge your batteries with that? And what's more, why use those
batteries in the first place?
And if it is true that such a "negative energy spike" is indeed created in the immediate wake of a normal high voltage pulse,
as Bearden claims, then why do we need the rotating motor assembly at all?
Now there are Bedini-type circuits that do not use a motor to charge the batteries... But they're still charging batteries...
Does the "negative energy transduction" only work in batteries, somehow, and contrary to what Bearden describes so extensively?
Or does the "negative energy" itself not exist, perhaps, and is it 'just' a very high positive charge resulting in the abrupt break
in the transmission line just after the very high negative charge pulse has passed? Is Bedidni charging his batteries with that, perhaps?
So, perhaps, indeed deep cycling his batteries? ;)
