the Kubikop motor
Started by DA, January 25, 2008, 08:49:03 PM
pese
Jes the DMM make problems if not sinuodial AC  or not proper DC.
But the voltages aon Battrie is same if you look with Ananlog or digital
Volt-meter !
the batteries have the same function as big condensors ,
so the voltages are NOT overlayed with RF or pulsed voltages.
Bu be shure you can use parallel to the Batteries aditionally RF blocking
cindensors. 1000pf  + 0.1 mf  ( MKT or ceramics.
Other Motor found an yourtube now;
http://www.youtube.com/watch?v=ArX7BDY1XRM&feature=related pulse motor 225hp
Pese
hoptoad
Quote from: pese on January 27, 2008, 04:53:34 AM
Pese
@Pese
We'll have to agree to disagree on the finer points of RF in battery circuits. For a vivid example of RF being conveyed by the battery itself,
check out this link at you-tube : http://www.youtube.com/watch?v=t45OyvaAc-0.
Here is a quote of the written text associated with the video : "Circuit is powered by eight AA batteries. Terminal voltage is 11 volts. Current is 110ma. AV plug is grounded to the house wiring (screw on wall outlet plate). The tubes are both touching the battery pack, no electrical connection. The circuit is a modified version of the Thomas drive circuit outlined on the website Dr Stiffler.com More info at this link"
The circuit used in the video is a variation of DR Stifflers circuits found in  http://www.overunity.com/index.php/topic,3457.0/topicseen.html
Cheers from the Toad who Hops  :)
pese
Jes , but the Stiffler is another Device ,
i have  only -tried- to learn ala a little bit for the problem to read voltage with digital Volt and Amp Meters if pulses and RF will "disturbe" the Values on Meter.
Analog Meters are mor accurate , DMM can be used , if Condensor between + and -  directly
connected on meter , will stop any RF and equilize also fast changing DC voltages.
The Stiffler Invention is have not followed. The Schema isnt in the link !
8 Batteries (1,5V) mus be 12 volt (new batteries 12,9 Volts.
chargeable 1,2Volt AA have only 9,6 volts.
What is used to have  11 volts?
(Week 1,5V bateries?)
Can you find out , it work on Zinc-carbon ore alkaline ?
can it work at the both battery types.
The 110mA are they correct, (IF RF is in the paly, and DC voltage AND Meter is not
"blocked" via condensors against RF, you can belive values on meter.
jes its possibel to light up "neon"-lamps via rf (sikes) with RF power, i "find "this
40 years ago out in groep of radio amateurs.also following life in my profession.
But never comes more out than was the (real= input.
Pese
Ren
Ive had different DMM readings by simply placing my hand next to the meter. I doubt their accuracy with anything of a pulsed nature now.... :( :D
kubikop
Hi all
I would have like a link sent to me about this.......
I guess I found it on my own though, I wonder what else is out there.
When I get a chance I will hook up my circuit this way again with my Oscilloscope because you can only ever know by doing not by posting.
I will youtube the results..
Please send me a link or invite me to forums about me.
Paul.
