Anti-Gravity Machine
Started by FreeEnergy, June 01, 2006, 08:37:28 PM
acp
QuotePosted by: FreeEnergy
Insert Quote
someone build this and post a video please Smiley
Why don't you build it and post a video?
Anyway, when the two funnels taped together reach the 'top' the of the first ramp, you will find that you have to raise the funnels to get them onto the next 'ramp' lower down. If you read the original webpage again it explains what is happening.
Hey, maybe someone will invent a free energy maschine that runs on pure stupidity next.
This will not work, as the center of gravity of the 2 funnels has already gone down
after the first ramp. Read the description in the link of the first posting !
FreeEnergy
hmm ok then whatever you guys say ;)
peace
FreeEnergy
what if the ramp is a 'sliding ramp' where the two funnels taped together keeps trying to reach the 'top'?
russwr
100% floating gyroscopes before 1900
You already know about contemporary articles in journals and obscure science literature on low percentage of weight loss of spinning flywheels and gyroscopes. Even a book was published years ago on such matters. There was also the 100% floating gyroscopes device of John W. Keely of early 1890's. He tinkered in his Philadelphia machine shop for years perfecting his system, which the last prototype was called "Vibratory Lift". Without electric motors or electricity for power to his shop, he used precompressed air in thousands of pounds as a motive force for tools. The air spun (3) heavy sirens - "flywheels" up to speed. The "certain" desired vibrations of air tone of harmonic ratio was transferred to 1 ton steel base structure and differing rpms varied the tones. Air removed. With test instruments indicating proper setting, the whole structure rose slowly upward, hovered, then settled back down with decreasing RPM and friction taking over. Years later the final set up as witnessed by engineers, reporter, secretary, and vice president of Keely Motor Co , allowed the apparent lifting of (3) ton pressure tank that was raised up and placed upon a 6 ft high metal tripod and was connected only by the end of a series section of thermocouple wire to vibrators matrix. The original three Keely manuscripts are still missing. Aerial Navigation may of been also demonstrated to War dept and offered for sale. There are about 500 of us around still studying the different works of Keely.
2 Tons Lifted! Vibratory Lift Invention
SPECULATION ON OLD EDITORIAL - Who knows about the special gravity demonstration by John Keely to officials of Keely motor company during 1890's? A 6000 lb sphere pressure tank was said to have been lifted and put atop a 6 ft high tripod with the only connection means being a stiff, thin, horizontal wire. The statements made to the press by the witnesses seems fantastic, and if they are not all flat out liars, how could gravity control have been technically done?
The heavy, thick walled mass would have to be struck strongly with hammer to set up vibration. The internal hollow contained a harmonic
vibrator bars matrix that continues the resonance effect and allows for further applications.
The other portable unit contained brass vibrators probably set to 66 2/3 harmonic of the steel structure. (Repulsion of masses at same
level of harmonics comes with 66 2/3 :100, Keely) Since Tesla's literary works were available at that time, he deduced the harmonic of the whole earth as 8,- 16 hertz/sec. When heavy mass is harmonized with Earth, further vibration effects were possible with ratios applied. After final settings, the long sectional wire was attached at one end to sphere tank and was of heavy gauge
thermocouple type. Wire was wrapped in circle around, just below center line of tank, for method of holding on to it. Opposite end hooked to vibrators unit, Two purposes served, as having stiffness of wire end to lift weightless
mass for placement up above 6 ft higher, and also for creating higher frequencies to be applied to steel as upper inharmonics of the
node created by Platinum and Silver junction. Further multiplication, (N squared),of frequencies was done by adding loops of small Platinum, Silver, or Gold wire for
more nodes of interference waves. The device was said to of been hand held by keely during use when three ton tank was raised from floor. Keely later said - " The psycological effect of this experiment was disagreeable!".
Comments????
P.S. have you read N.Y. Journal and Advertiser, editorial jan 29, 1899 pgs 12,13,19? Get it!
From cross referencing Keely data, I determined the special connecting wire used by Keely in the 1890's was thermocouple and thermopile type of ag, au, pt. (Not alloy of 3 metals , not layered wire of 3 metals as previously thought. Verification also by reading the exact use statements of such wire.
Your response requested.
From Russ, another Keely researcher
