Thane Heins Perepiteia.
adlep
Quote from: aether22 on March 20, 2008, 05:34:22 AM
I have never said such a thing before and don't say such things lightly, I am prone to discounting such accusations as they retain a plausible deniability factor.
But never the less based on things said in PM I very much feel polarbreeze is a spook.
I know they exist but what I can never figure out is who pays for them, do you think they just pass that hat around and do it as a group or does one oil company, intelligence agency etc... send their own people based on their own criteria and let the others reap the benefit of a continued status quo.
I think that Polarbreeze has a very healthy dose of a skepticism, but I don't think he has malicious intents. His posts provide for a healthy perspective and as such they should be tolerated.
If you can have him say: "Wow it works" then you are doing something right for sure.
Just relax and ignore the noise :D
Thane seems to be on something, especially with his openness in regards to the setup.
JustMe
Whatever his intent, he is the author of his own problems on this thread, that's for sure.  Couldn't alienate himself much more if he tried.
innovation_station
well what can i say
vince's setup and observations....
proves that there is more than just bemf at play here as i first thought   hummmmm....
so how about some kind of magnetic feed back loop ....
well i drew a pic of my turbine useing the postivite feedback loop ..... concept  thus allowing acceleration after starting
i have the same drawing with a starter motor it can be found in my turbine thred in half baked
here is the link for it   http://www.overunity.com/index.php/topic,1977.165.html
ist
or ground loop through your body ??
OilBarren
Quote from: polarbreeze on March 20, 2008, 08:19:09 AM
Quote from: powerunlimited on March 20, 2008, 06:12:56 AM
....I use a variac to control the voltage,the results are  the same as your set up
run adjust variac to get a stable speed,short coil,wheel speeds up,open coil wheel slows down.
So far so good. Here are the measurements needed to quantify the effect:
1. What is the power input in each of those cases? To calculate it you need to measure the voltage, the current and also take account of the phase difference between the voltage and the current.
2. If the input voltage changes when you change the coil connections, you also need to measure the power with the input voltage held constant, otherwise you'll be having an unknown power dissipation in the variac. You need to readjust the variac to keep the voltage constant and then measure the power as above.
Please post your results because I'm working on the theory side of this.Thanks!
FYI - YOU ALREADY HAVE THIS INFORMATION - POLAR.
polarbreeze
Quote from: OilBarren on March 20, 2008, 01:03:35 PM
Thane, I do not have this information for Vince's experiment AFAIK but if it's posted here somewhere and I've missed it I'd appreciate your pointing me to it. Thanks.
PB
