Steven Mark´s associate Jack Durban comes forward with more info !
Started by zapnic, March 17, 2008, 04:28:58 AM
leeroyjenkinsii
This all seems like a bunch of bull to me.  Has anyone gotten any of these devices even close to working yet?  Anyone can fake the Steven Mark's videos.
Tink
Quote from: Earl on March 20, 2008, 08:14:19 AM
@AM
One of my lines of thinking is that the TPU is utterly, stupidly, totally SIMPLE.
So simple that it uses no electronics at all, except to start it.
Once started, no semiconductor, no spark gaps, no nothing.  Only an extremely clever arrangement of coils that forms an aether oscillator.
My thoughts have only started on this and I need to let this go through my neurons a lot more.
Earl
Quote from: AhuraMazda on March 20, 2008, 07:09:49 AM
@Earl
Due to the lack of high tech switching mechanism in the TPU (as described by Jack), is it safe to conclude that earth's magnetic field and Schuman resonance are
in fact the source of the energy captured by the TPU?
Perhaps the insertion of the magnets may had nothing to do with reed switches but to induce a small current in the coils which avalanched into a large one?
AM
I agree with Earl,...please people,..think simple!!!
It is just the coils and the way they interact with each other, no fancy crap what so ever,....keep it simple!!!
Synergy is the key to free energy.
Unicron
Edward Leedskalnin's Perpetual Motion Holder
simple enough?? ;D
wattsup
@Earl
First of all thanks for Re-ing your posts and not taking this request in a bad way.
This is an OU device and not a tv or any other FCC regulated device. When it comes to that point in time the solution is obvious and does not have to be integrated into the device as it stands today. That would be the least of ones problems.
There are probably only 7-8 main components to the LTPU and I doubt it very much that he would use even 2 of them to fix power output. That's 20% or 30% of the components and this does not make any sense at all. Not for what the device was used to show in the demos.
If these two fine wire chokes are for the output, they would have fried at 1000 watts plus when he did the sparking they would have fried again. Come on man. My 1000 watts inverter blew some months ago and taking a look inside, the output choke is heavy gauge with maybe 10 turns.
I will quote you;
There are unending different types of common-mode chokes.  The finer the wire the less current and more inductance. Unquote
That's exactly the situation here. OK, so I will stop beating around the bush cause I thought someone would catch.
Those fine wire toroids are used as self-induction required to charge those yellow caps that are required to discharge current through the coils in reversing polarity. Those chokes are not required for output control. They are both the starting point and end point in a loop that changes polarity on charge and discharge. But I'll try and make a diagram soon on t his and plan a first build.
Mr. Durban had enough time to realize the coils in the LPTU were arranged as four coils 90 degrees each. He says there were two layers but this would have to be further investigated when the clear video becomes available.
So, why two chokes? Why not one nice fat bugger. Because those chokes are used to control a pair of coils each around the TPU.
sparks
    I think the permaent magnets serve the same purpose as a magnet in a speaker does.  It is the reference magnetic field.  A saturable core reactor controls the high power circuits by changing the magnetic flux of the core.  This way a very small dc input can control a very large ac current.  So the magnetic field of the pms set the reference flux of the sensor winding.  Any change in this flux field is going to be sensed by the coil.  So now the system knows what magnetic flux is doing in the aether.   I am sure that these magnets are not the kind Mythbusters clown with but are matched to the gauss of the Earth's magnetic field.  Now you know what the aether energy is doing so you can phase lock on it.  Amplify this input and make the larger windings react in phase with the aether.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
