HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
wattsup
@eldarion
Do you mean the cap @EM was pointing to earlier or this one when he turns the tpu upside down. lol
Finally got the image grabber to work. Now for the fun to start.
eldarion
Quote from: wattsup on April 16, 2008, 08:19:13 PM
Yup, that's the one...
My question is: where the power is coming from to get the device started?  Maybe that capacitor is charged from an external source prior to the startup shown in the video, or maybe the "capacitor" is actually a AAA or AAAA battery.
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
eldarion
Quote from: wattsup on April 16, 2008, 04:39:26 PMBut he made a mistake when he showed the FPTU. lol
Look at the meter when he connects the probes. He knows that meter off by heart and would not putz around so long with the selector buttons. He put the probes on, the voltage started going up around 26 but then he pushed some of the buttons to remove the voltage reading. He then put the magnet then pressed the proper meter button again to show the voltage. We could never see the meter readings in the old video. lol
I agree with this wholeheartedly--when he flips the FTPU over, watch the magnet (it is rather tricky--it is not in the position you might expect!).  You will see that the magnet is actually standing on end quite a distance away from the center toroid, and not touching anything other than the inert plastic disk.  That particular magnet does not appear to have any bearing on the operation of the device...
Eldarion
-- Thomas Paine
Cap-Z-ro
Wow there's certainly no shortage of resourceful theories here...
Is it possible the the upper and lower rings of the Graves patent found by EM (excellent research of the material BTW) may be collecting the opposing negative frequency mentioned by Aleks, and in so doing causing the primary and secondary coils to resonate and radiate energy ?
jdurban
"In all of our discussions we should not forget what SM said in the first video.
"we tune into the earth magnetic field, which has an inherent frequency""
Likely a harmonic of the cavity that is ideal for tapping.
Windows has detected a mouse movement and will now reboot.
