HIGH QUALITY TPU DVD Video Released from Jack Durban
Started by Jdo300, April 14, 2008, 02:40:29 AM
otto
Hello all,
I had to earn my money so Im back.
I see 4 1/2 turns of the blue wire!? I suppose the other wires are the same lenght of 4 1/2 turns.
Mannix said  - not including the CONTROL wires!!
This means we are looking at the........
Otto
BEP
@Mannix
I see your helices, wire ends at the quads (inside and outside) and the reverse handedness between the two layers. I also see 4 conductors per layer and the white wire only on the outer edge.
If your connect the innner ends between the top and bottom (left and right on the image) you have current flowing opposite directions but creating the same magnetic polarity in each layer. (like my EMP coil 8-)
Did I earn a cookie?
dani1
BEP
The white wires appear to be just a common point for the windings.
I expect between the two layers the magnetic fields will be the same polarity but the net electric field will be near zero.
Nature abhors a vacuum.
Now do I get a cookie?
wattsup
Glad to see some are concentrating on the rings and eventually a consensus can occur.
That's why I said we have to look again at the rings. In a previous post, I was indicating that there were two wires in the ring each cut as a dead end. But there is no dead end on closer look.
On the top ring, what is obvious is at least 3 turns of a continuous loop. The 4 or 4 1/2 would have to be firmed up, but there is at least 3 turns of a single wire per ring. Something like a mobius.
I have traced the wires from the top loop going into a connector and you can see the bottom loop also goes to the same connector. Otto and Roberto, does this "ring a bell' .lol
