Selfrunning cold electricity circuit from Dr.Stiffler
Started by hartiberlin, October 11, 2007, 05:28:41 PM
Loki67671
Quote from: RStiffler on May 05, 2008, 02:54:33 PM
@All
Part#2 of my DIY calorimeter
http://www.youtube.com/watch?v=UsChd3svkho
Yes sir! Sensors arrive tomorrow. It will work! No whiskey required.  ;D
Best
"When the water stinks, I break the dam, with Love I break it" .............Loki
"One must be completely immersed in the cold darkness to truly adore or loathe the light" .............Loki
Science, my lad, is made up of mistakes, but they are mistakes which it is useful to make, because they lead little by little to the truth." - Jules Verne
Feynman
Hello,
I just want to say I was able to replicate the electrolysis experiment.  Gas evolved from only one electrode.
Cheers,
Feynman
nickle989
@the Dr. .. here is a closeup of the coil setup ... 26AWG , the ambient temp is around 24c
Top Coil - 2.2 uH - 12uH
Bottom Coil - 7.3uH - 26uH - double rap
I am currently using the top coil.
The bottom photo is of coils that I was messing around ... the slug is from a computer power supply.  Unfortunatly it becomes saturated to quickly for the high frequencies being used, which would make sense as a computer power supply does not need high freq's but more power at lower freq's.  The coil on the right is where the slug came from.
The coil slug that I am using comes from a old pioneer audio amp from a local repair shop.  I also was using a tunable coil in place of 22uH at one point, from an old pager.  This was on the large board.  I will try it again as it maybe able to tune it in a bit more ... or it might just not.
It seems to me that the plate is charging.  At different times when you touch it the light will be brighter but most of the time I find it get dimmer.  Observation leads me to think the rush of surrounding charging ION's is leading this power, there is something else going on here that I can't quite put my finger on yet.  I am hoping that a friend of mine will lend me his spectrum analyzer from work.  No sense wasting energy or draining it to ground when one can put it to good use.  The NEON gas will certainly be excited via frequency causing friction.  I will be now testing some other gases to see what other observations can be seen.
I have seen some very interesting results while trying to get to this stage.  How long have you been at the SEC development? , meaning no offense.  There are some findings that I have seen that made me go this can't be right! some way so cool.
@Loki  - there are some things that I would like to go through ... I would like to keep it in the thread as long as Dr. Stiffler is alright with it .. these things may go off half cocked .. lol or maybe we can a new thread.
The scope shot is there to get me to the stage.  I can remove the scope from the circuit and it does not cause the circuit to fail.
Loki67671
@All
Just slightly off subject, but Doc brought it up  ;D I have been a dedicated winemaker, beer brewer, and motor fuel maker  ;D for years!
I've been known to run internal combustion engines from a still and stand a wind turbine up downtown. Yep! In any case.
The sensors will show up tomorrow, the DAQ is RS485 so I can place it anywhere I want and monitor / control it and others from my desk. Windmill software is free. Have to check and see if Open Office Spreadsheets supports DDE conversations. The PC is loading right next to me. I'm going to include over temperature shut-down and safety monitoring just in case it turns into long runs or troubles.  8) Here we go.
Best regards,
Jim
DrStiffler
@All
Anyone out there that has a thermal image camera? If so do you have a SEC Exciter PCB? If you have the equipment and no PCB could I send you one to have a couple of tests performed???
Thanks...
All things are possible but some are impractical.
