Bessler Wheel Theory by Alex
Started by Alexioco, May 14, 2008, 10:31:22 AM
Alexioco
Besslers Wheel By Alex
I have spent sometime studying Besslers wheels and I am going to go through the ones I used to combined to get a possible working wheel.
First I would like to say thank the members/staff etc... for the information this forum has supplied for me. Also I praise our Heavnly Father for the incredibly inspiration he gives me...
MT 10: This picture has been drawn backwards and upside down, when correctly positioned the arms/levers being curved focus all the of weight to the end of the lever creating a more stronger effect, so MT 10 can be used in the wheel, also note that with the levers being curved, then can be positioned like the levers in MT 31 so the curved part can rest on the axel allowing the weight at the end to not face upwards when resting.
Example:
MT 14: The connection by the small weights lifting the cross tensions is a good idea, but there is to much friction on the pull and there is too many weights being used to pull just one cross tension up, the bottom weights serve no purpose, they just hang there, but there is something good to say about this which is that the weight connections are good, but something is missing as will be seen?
MT 15 This wheel works in the same way as MT 14 except that longer poles are used which is good because the weight in a wheel that further from the axel is the main weight to turn the wheel.
MT 25: This wheel is good, and this time the weights at the bottom are doing some work as well as the weights at the top.
Now gather all of the good points in the above wheels.
MT 10: Curved Levers
MT 14: Cross Tensions
MT 15: Making the cross tensions longer than the weights used for pulling
MT 25: Both top and bottom of the wheel are doing work to shift the weights
Now let?s start putting this wheel together?
MT 10: (I have not curved the levers as they will be hard to see as my drawings progress)
MT 10 14:
MT 10 14 15:
MT 10 14 15 25:
This is how the wheel works:
When the inner weight falls out at the top and the inner weight at the bottom falls in they drive/push the long tension in at the bottom and pull out at the top; weights acting in pairs and also pair of pairs acting together. The weights on the long tension can also be heavier than the inner weights. Reason for this is the strength of the mechanism due to its position of levers?
A Video shall be posted soon of the wheel in rotation soon.
I am not happy yet though as all of the important wheels are not in it.
The following MT?s are needed for this wheel in my opinion.
MT: 11 MT: 18 MT: 19/20 MT: 27
If I were to improve the wheel even more I can add MT 19/20 also using curved levers like MT 10 and it will look like this.
http://i31.tinypic.com/1178h1h.jpg
Now here is something very interesting I found about MT 27
? Bessler wrote:
MT27... This is the previous model slightly larger and altered: A are the levers interrupted at B and having a heart-weight at C, and D are the straps, or cords, and chains. It needs no further, lengthier explanation. This view shows what the thing might do if several things of this sort were placed next to one another along an axle-shaft.
Well its obvious it wont do anything on its own unless somthing was put with it, so what does beesler really mean? Well if you place this mechanism 4 times around an axel/shaft, look what you get...
If anyone wants to build this wheel, then they must ask me on PM or Email.
Also there are a few problems which are not shown in the drawing which I will not mention here, rather, you will have to ask me privately, really its not important unless you are building in which you will become stuck.
P.S For showing you this, I would greatly appreciate anything interesting about theses wheels I might not know and any other help would be great, thanks...
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
Many thanks Alex !
I will now begin to simulate these wheels with WM2D.
What is the heart type thing ?
Is this a weight ?
Are there only rods in these wheels
or also ropes ?
I am going to use now only rods for the simulation,
because it is much easier to setup.
I still don?t understand how to design pulleys in WM2D.
Maybe someone can teach me how to do this ?
Do you have to first use a wheel and then click the pulley
icon and fix the pulley rope to the wheel ???
I don?t know if you all did see my last movie from yeasterday night,
where I simulated the basic wheel of P-Motion, which does not work
and always balances out...see here:
http://www.overunity.com/index.php/topic,4589.msg96537.html#msg96537
Regards, Stefan.
Okay, I have set this topic sticky and renamed the old
topic to:
Alex's MT Combination
So I think it is best this here should now be the main new topic to discuss Alex?s theory
further over here as it also has the right topic name:
Now back to the WM2D simulation.....
I don't know how practical wm2d but you could also try Sketchup in combination with SketchyPhysics. The advantage is that it's true 3d and imo shapes are easier to build and what not. I'm currently playing around with it...here's some showcasing
http://youtube.com/results?search_query=sketchy+physics
Broli,
cool,
definately the way to go in 3D then !
This is what all gravity machine builders have been waited for !
But for today still on with WM2D.
Many thanks for this great tip.
Regards, Stefan.
