Thane Heins Perepiteia.
OilBarren
Quoteand that is with 18 magnets on the rotor!)
IS THAT 18 x 1 OR 6 x 3 BECAUSE I WOULD SUGGEST THE LATTER.
QuoteOne thing though, do you always have meters so far away because if they are closer things get screwy, or is it just how you prefer to work or for clarity of demo?
I PUT THE METER BOARD FAR AWAY SO THAT THE PEOPLE I WAS DEMO-ING TO COULD STAND BESIDE ME AND CLEARLY SEE THAT I WAS NOT TRYING TO PULL A "FAST ONE".
IN HINDSIGHT I PROBABLY SHOULD HAVE BEEN WALKING ON WATER AT THE SAME TIME AS WELL!
Thane
OilBarren
AETHER,
DO YOU HAVE A HARDWARE STORE CLOSE BY WHERE YOU MIGHT BE ABLE TO PURCHASE THE SAME STEEL PIECES IN MY ORIGINAL PROTOTYPES?
LARRY ARE THESE WHAT YOU USED AS WELL?
Thane
aether22
Quote from: OilBarren on May 14, 2008, 07:15:59 PM
Neither, I went with 8 x 2.
Thane
Come on, clearly he has just taped a bunch of Jesus lizards to his shoes!
And the water isn't turning into wine, only grape juice, what a crock.
aether22
Quote from: OilBarren on May 14, 2008, 07:20:52 PM
AETHER,
Thane
Please clarify: 'SAME STEEL PIECES IN MY ORIGINAL PROTOTYPES?'
LarryC
AETHER,
Thane
Not sure if exactly as your original, but the specs follow:
The core is 5" long using 1/8" thick flat bar from Home Depot to create a 1 1/4" by 1 1/8" oval to try to match the 1 1/8" cups.
Widths in sequence were 1/2, 3/4, 1, 1 1/4, 1 1/4, 1 1/4, 1 1/4, 1, 3/4, 1/2 across the outer ends of the core. No 1 1/8" available.
Larry
