Bob Boyce TPU thread
Started by hartiberlin, July 26, 2007, 12:03:41 PM
Bob Boyce
@all
I have been sidetracked trying to get some decent test equipment on my bench. As many know, I have had one heck of a time with getting JUNK delivered to me from those darned surplus equipment sellers on eBay. The suggestions of leaving bad feedback or researching sellers do not really help when it is usually not me doing the bidding or buying. Much of this stuff was being bought for me by a friend that has broadband. I do not stand much of a chance of winning bidding wars when I am on dialup. Bidding is intense because apparently, due to misleading descriptions, the other bidders do not know that they are bidding on potential JUNK. It is really frustrating trying to tell which seller is being truthful in their listings and email correspondence, and which is not. Out of 4 identical Wavetek 859 units, I had enough good parts to make 1 working unit! The main issue with these is corrosion. Corrosion on the chassis, mainboards, plug-in cards, and front panel boards. Dead or partially dead front panel keypads with hidden corrosion in areas not accessable for examination or repair due to the keypads being glued in, hence the corrosion is sandwiched between the front panel plastic and the kepad PCB. Almost every time, units bought that were honestly advertised as DOA for parts only, were actually in better condition than units from the surplus dealers that were advertised as "powers up, but untested". Yea right! The 115VAC powered fan comes on when power switch is turned on, but the electronics were trashed in almost every one of those.
Now for the good news ;-)
The HP 54110D scope arrived, and with the use of an attenuator out of a parts unit HP 54100A scope I bought pretty cheap, it is now working perfectly as far as I can tell. I even managed to get the parts scope working somewhat, so will keep for parts.
The Tektronix HFS 9003 Stimulus System seems to be working nicely, and the SMA to BNC adapters from Hong Kong finally showed up. It may take me a while to learn how to operate the beast though.
I managed to repair one of the HP 8116A 50 Mhz Pulse/Function Generator units with parts from the second supposedly working unit that arrived DOA.
I repaired the HP 8111A 20 Mhz Pulse/Function Generator, as advised in my last post, I listed it on eBay because I don't need it now.
And as I mentioned before, I managed to repair one of the Wavetek 859 50 Mhz Programmable Pulse Generator units. I have one more good chassis and board set, if I can locate another front panel with a good keypad. I may sell off the "boat anchor" junk units on eBay. The ones that were bought from the surplus dealers, if anyone is looking for parts units. I will certainly be honest about the condition if I do decide to list them.
As some of you may know, I have been drawn back into the hydroxy research, due to being nominated for a grant that is being managed by the New Energy Congress. I do not know yet if I was one of the winners, but last I had heard, I was in a tie for second or third place. I guess I will find out if I get a check in the mail ;-)
One of the NEC members bought me a Toyota Prius hybrid with no strings attached. I have been spending a lot of time getting familiar with the onboard systems in preperation for conversion. The current plan (pun intended) is to convert this to an electric vehicle, in order to get it legally retitled and registered as an EV. I need to do this so that this Prius becomes EPA exempt under the ZEV rules.
I intend to build a charging system that can keep the batteries charging for long duration driving. Initially, I will be setting up a hydroxy gas fueled genset, as that is a system that I have had very good success with. I do still intend on pursuing the pure energy type toroidal power system, but that is going to have to go on the back burner for now. I can't risk having direct electrical connection to the vehicular battery bank until I am sure that the complex onboard systems are safe from getting fried.
Bob
EMdevices
Wow,  this is the first I hear of this Aureliano Horta guy and the self running motor.   How awesome.   It is definetely related to the Thrapp motor.  I got to duplicate this technology, seems like a focused effort since we see the diagram with the motor and generator connected to the same shaft,  and we see the control circuit functional block.  Now all we have to do is fill in the blanks.  It's like doing system engineering, here at work.  Topdown design approach.
EM
Bruce_TPU
MarkSnoswell
Quote from: EMdevices on May 21, 2008, 01:37:11 PM
EM
Aureliano's company is ET3 ... this is the Mexican group I have visited twice. The motor is very old - long since (20 years) left behind. All based on the same principals as TPU, Spherics, Energia
Dr Mark Snoswell.
President of the CGSociety www.cgsociety.org
Hi Mark,
Why didn?t they publish the motors
some more  ?
Where there still problems ?
