New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
ramset
I'm posting this comment By "Harvey" at Energetic,
Because He has done some research on why this could work [the last part of this comment]
Quote:
Too bad the battery holders . . . I mean upright supports are not transparent
Sadly, they are large enough to not only house a battery stack but also a motor to drive the axle. All that is needed in that regard is the energy addition necessary to lift the stator magnet out of the conservative loop.
Because the cam would provide a gravity assist in normal conditions, it would have been good to see the device at rest with the cam down. If it truly worked as shown, without any momentum, it would settle calmly to a minimum point of gravitational potential energy balance with the magnetic fields. But if the rotor was driven by a motor, it would not come to rest in this way, but would begin bobbing as it tries to lift the cam against the gravitational minimum and finds its resonant position.
Since these two conditions are avoided (transparent supports, natural state of rest) the video is suspect.
That being said, I have shown with my M.A.P. tests that energy can be extracted from these two conservative fields when they are separated properly into non conservative parts. This device may exhibit such a separation. In my tests, mathematical projections showed there was approximately 10x the energy available for extraction than was required to drive the trigger mechanism. So while the output energy was minuscule, it was cumulative.
Why has Roobert33 removed the video?
YouTube - Roobert33's Channel
Thanks Grandma
poynt99
From what I can tell, he is not wearing a wristwatch. Also, if he was, it should have also affected the RPM when he was moving the unit around, but it did not appear to.
Careful observation seems to indicate that the RPM throughout is somewhat erratic.
.99
XS-NRG
Tito L. Oracion
The device looks simple to replicate, why don't we try it first before we conclude.  ;D
for the truth will set you free. John 4:26
pultimo
Beautiful! Fake but beautiful..! Ideal for Xmas!
It looks like a pulse motor: I bet the magnet below IS NOT a magnet, otherwise its movement is totally unexplainable. If it was a real magnet its movement would SLOW DOWN and NOT accelerated the wheel, so....fake, but beautiful
