New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Arrow
Here we have new spiral V-gate concept to avoid top magnet mechanical up/down movement .
Comments in the YT video comment section.
Concept must be tested. I will inform you about tests result with this real rotor video even if it will bring negative result.
http://www.youtube.com/watch?v=x8jTa04MVcM
We are taking source idea from many US patents like this:
http://i069.radikal.ru/1111/a6/0700f7954b42.jpg
http://s017.radikal.ru/i401/1111/09/433be6bd9fa8.jpg
truly
rob
gauschor
I find this V Gate most interesting.  For it seems that the torque is strong enough to make more than 1 full rotation (if you remove the magnet on top) the work to lift the magnet up must be less than the remaining torque to make it move permanently. This seems to be the difficult point :( Unfortunately I got no idea how to do that either, just wanted to say keep the heads up and continue experimenting.
Arrow
Quote from: gauschor on November 27, 2011, 11:16:25 AM
Hi dear gauschor,thanks for info Sir!
my flat V gate show us interesting data - first ~75% path comming form narrow shape of V structure to wide has most strong pulling force, other 20-25% up to the SP has less torque than first ~75% of v gate lenght.We are not going to remove top magnet, you did not understood me right.It will stay at place but we are going to test spiral V-gate rotor structure at vertical position because we can balance rotor relevantly to help it pass sector with less magnet force and pulling force. That is going to put wide V gate part low aganst of top magnet(out of magnet field), and we want to test all these thing without up/down movment to see if top magnet passing SP in such configuration.
see this video again to undertstand what I mean with spiral rotor:
truly
rob
Arrow
found very good instructions on line to built 3D Printer mechanics
http://reprap.org/wiki/Prusa_Mendel_Assembly
Also , here is the manual for construction same printer in PDF format
http://depositfiles.com/files/o875d8iuz
Hope this will help you to construct easy CNC to replicate your motors staff.
Absolutely amazing staff is 3D printer which prints your mechanical staff from 3mm ABS plastic rods
truly
rob
Arrow
Hello dear people, I found who are creating CO2 mostly in US - It is USPS post
We are fighting with who?:)) Monsters with idiot Brain?:)))
  I am absolutely confused and sad to see my staff in this crazy delivery path. See attached pic of map http://s50.radikal.ru/i130/1112/c8/fdf316a72b5b.jpg
I had pay only 16$ for delivery and guess that USPS post mail service computing system do not have even "kid brain" data base to cut transportation expenses. Guess  they have big problem with fuel cost overdraft per year :( This is crazy to understand that we have to pay USPS more money to cut the path of delivery and USPS service fuel consumption... guess they are crazy. That is why China so smart and took all US and not only US market, sorry for that:(
  2000 km magnets running over the 1/2 US and still on the earth, crazy to understand that, sorry:(
Detailed Results:
Processed through USPS Sort Facility, ,2011,JAMAICA, NY 11430
Processed through USPS Sort Facility,, 2011, CHICAGO, IL 60666
Shipment Accepted, 2011,  PETERSBURG, WV 26847
Truly,
IT Department, Armenia,Yerevan
Robert Sahakyan
Telecom DC Development PM
Data Center IT Infrastructure Chief Engineer
