Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
ElectricGoose
I tend to agree with Mark on this one.  There are many things here that do not ring true.
1)  Those high revving two stroke gensets require a high volume of HHO/any 'gas' fuel to be produced to sustain operation.  That particular cell is not big enough nor is it being delivered the adequate amount of amps to generate sufficient gas volume.  Common sense dictates that this last comment be true otherwise the genset would not be able to run the load.
2)  Running a ICE inside a building is proof of NOTHING.  For those of you familiar with GEET technology, even running air vapor through a water/gasoline mix (as Mark suggests) will produce VERY clean exhaust (but still with the telltale hydrocarbons).  The exhaust is cleaner due to the 'water injection' and has a twofold effect of increasing the octane level (if gasoline used) hence burning the fuel more efficiently and secondly having a anti detonant effect.
You have to calm down and see past the bulldust here.  I believe what they actually are doing is putting a very small amount of alcohol based fuel (like Ethanol) in the water bubbler.  Normally, less than 50/50 mixture and the engine definitely wont start AND this mix requires heating first if you don't have a geet reactor attached.  However, IF you were to make this mix say 80% water and 20% Ethanol and then supplement the air intake with HHO, this will be more than sufficient to generate an overall enriched 'combination vapor' where the engine would run extremely efficiently.
If what Mark states is true (about these folk refusing exhaust analysis), I almost 100% guarantee this is what they are doing.  They are probably waiting for a gullible investor that doesnt insist on tests so that they can continue with the HHO research which is a LONG way from self running by itself.
That's it.
E-Goose
Breaking the Enslaving
http://www.youtube.com/watch?v=aQ5DCzBry5A
Turn up your volume !
Enjoy !
Happy Christmas to ALL !
Best regards, Stefan.
ElectricGoose
Quote from: hartiberlin on December 23, 2010, 07:23:22 PM
Enjoy !
Oh dear me....  Is the desire to believe that bad that you forgo all reasoning???
Takes more than a silly youtube video with 'feelgood' soundtrack to convice me.  Show the blueprints, submit to testing/peer review and not some flakey video of running a motor inside a room.  I can do that now with the method explained earlier (and more).
E-Goose
XS-NRG
tishatang
This is not a high revving two stroke engine.   It plainly shows OHV on the engine cover and timing gears to get rid of waste spark on a four cycle engine.  I want to believe til proven otherwise.
Tish
